Need a tune but dont know where to start??
This is only when it sits running. I have had a friend follow me while I got on it and reved it and he did not see any smoke at all and it only does it that one time while you are backing out(been sitting running) if you rev it again there is not any smoke. I also basically need to know what to ask, how to be prepared and what to make sure gets done while I'm getting this tune. I will be using Jeff Creech at carolina auto masters if anyone that reads this has had expierience with them let me know.
TIA,
Shane
can't use the MAF ends on them (the MAF is bigger than
those ends anyway).
Call your tuner up and see if he already has the Z06 MAF
table. I believe I've seen people from that outfit post
here before. They should be pretty clued in.
In designing the C5 GM engineering did a ton of testing and from that wrote adaptive strategy that made assumptions as to air and fuel flow under different engine conditions. Changing those airflow parts, esp larger ones reduce the velocity and the A.S still functions as if the stock parts were being used and how it was programmed and does not change even with minor tuning. Most cases when the gas pedal is lifted and goes into decel with the larger airflow parts confuses the PCM and is adding or removing fuel when it really did not have to.
OK, you think I'm ok with those injectors. I have not purchased the MAF yet so it shouldn't be killing anything. I heard that the Granatelli MAF was not worth getting but I did not realize the ZO6 MAF was worthless as well. I plan on getting the LS6 intake in a couple weeks so I will wait to get the tune before I get that. I figured with the LS6 intake and injectors you should get the MAF as well but I guess not, thank you. My car is definately rich is there any other way to fix that without a dyno tune.
