Idle LTRIM question
Old Nov 24, 2004 | 11:16 AM
Terry Burger's Avatar
Default Idle LTRIM question
At idle (900rpm, stock motor with cam) I'm seeing around 1.5g/sec on the MAF reading, along with +15ltrims. In the left most spot on maf airflow vs. frequency table (cooresponding to frequency 1500), I have 2.46g/sec.
I'm a bit confused as to how to proceed.
Thanks,
Terry
Old Nov 24, 2004 | 11:55 AM
JS's Avatar
JS
PM Slowhawk,he really helped me Terry.
Old Nov 24, 2004 | 12:09 PM
HumpinSS's Avatar
try incresasing the ve table in that cell and see if that helps
Old Nov 24, 2004 | 12:16 PM
gojo's Avatar
Thanks,
Terry
Are you sure your not reading lbs/min?
Old Nov 24, 2004 | 12:17 PM
jimmyblue's Avatar
Moderator
The airflow at idle pretty much ignores the MAF and
uses the speed density airflow calculation. This result
points to an over-lean VE table most likely, though
other mixture affecting mods might be in play (?).
Old Nov 24, 2004 | 12:29 PM
Ah I got it. I'll work on the VE table. What is the secondary VE table for?
Thanks,
Terry
Old Nov 24, 2004 | 01:30 PM
jimmyblue's Avatar
Moderator
Secondary is for MAF faults, and if you try to tune SD
by taking the MAF out this is the table you have to work
with (and then back-propagate the changes to the Primary
table & fill in the blanks, if you want to go back to normal
operation).
Old Nov 24, 2004 | 07:08 PM
I fixed it by playing with the maf scaling table. Appearantly I was making some sort of unit of measure error! When I multiplied my maf scaling by 1.10 the ltrims went from +12 everywhere to +4 everywhere. I'll play with it more later to dial it in.
Thanks,
Terry
Old Nov 26, 2004 | 03:21 AM
stangkillin99ss's Avatar
i dont think thats a good idea. Most on here will say leave the maf table alone
Old Nov 26, 2004 | 07:37 AM
Another_User's Avatar
The airflow PID (from what I have seen) is always replaced with what the MAF reads. Even at idle when the PCM relies on VE/SD. I know this because at idle with the MAF plugged in my airflow would be about 5-6 g/sec. With the MAF unplugged it is about 10 g/sec. Any changes like a lid change what the MAF reads, especially at low RPM. You need to unplug the MAF, tune VE until everything is about zero, plug the MAF back in, and scale the MAF table (probably about 10% richer) until it is close again. Until somebody does a proper flow of an intake with a lid that is all you can do.
Old Nov 26, 2004 | 09:58 AM
As far as I know the MAF table is the only way to adjust fuel ratio, aside from minor tweaks in the VE table (which generally contribute only a small amount to fuel ratio). Let me know if I'm wrong!
Old Nov 26, 2004 | 10:36 AM
how is it possible to tune the Ve table with the MAF unplugged when the PCM reads secondary Ve for that situation and Main Ve for situtaions with the MAF plugged in?
Old Nov 26, 2004 | 03:41 PM
Well you have to paste the secondary over every even line in the primary, and smooth it out. That is as close as you are going to get. Trust me, it will be a hell of a closer than trying to tune it with the MAF plugged in. Go ahead and try to tune it with the MAF plugged in and then unplug it. Your car will probably stall from the massive amount of fuel it sucks in, and when you wake up from your gasoline fume-induced coma (you might see some cool stuff though...might get you high) you'll wish you hadn't wasted all that time trying to tune something that could not be tuned. LS1TECH should sell t-shirts that say something like "I'm the dummy who wasted months tuning a fueling table that couldn't be tuned with the MAF plugged in, and all I got was this crummy t-shirt". I think I already have one laying around here though.
I always update my primary VE table with the data I get from my secondary, even if I don't use it. Just picky I guess.
Old Nov 26, 2004 | 06:48 PM
Slowhawk's Avatar
LS1Tech Sponsor
You don't have to unplug your MAF to tune it in.Trust me
Old Nov 26, 2004 | 08:02 PM
A month from now, don't say I didn't warn you. Check out the details on my (yet to be approved last time I looked) tune I posted on Horist's website. This thing has not been sitting in a box at my house...in fact my wife is starting to rather dislike HPTuners.
I already made the mistake of trying to tune with that blasted MAF plugged in...but I got my revenge. It is now sitting on a shelf in my garage collecting dust.
Old Nov 26, 2004 | 08:55 PM
family sedan's Avatar
Please listen to everyone and focus mainly on the primary VE table. All around your car will run much better.
Old Nov 27, 2004 | 09:18 AM
Slowhawk's Avatar
LS1Tech Sponsor
Just to let you know,I've already gone through what your doing now and spent 100's of hours on it.There is a reason I don't waste my time doing the tuning that way anymore I have alot of note books full of information I've collected/tried in the last few years.
There is no reason to get rid of the MAF or tune open loop if you run a Cam under 245/250 on a 346. All the smaller Cams can be tuned with all the sensors still hooked up and have excellent idle/low speed driving that doesn't change on you.Just takes alittle time to figure out what works for your setup
I almost never touch the MAF table unless it is ported or a different MAF is being used.
Old Nov 27, 2004 | 09:33 AM
Bink's Avatar
Slowhawk -with all due respect, does the 245/250 closed loop statement apply if it's on a 106 LSA?? I'm running a 239/251, 106 - Open Loop, on the MAF ( I like my MAF ). I've rescaled my MAF at the lower values in order to get it to idle at about 15:1 AFR (FJO WideBand). Every other option I've tried to pull down the AFR hasn't worked very well. If I pull the AFR down a little more ( so LTrims will go negative) can I run it Closed Loop?? What do you think?? Thanks in advance!
Old Nov 27, 2004 | 09:51 AM
Old Nov 27, 2004 | 11:16 AM
Bink's Avatar
Fuel Adjustments:
IFR
F/A Multiplier Table(stoich)
VE Table
MAF Table
PE Table
Air Adjustments:
Idle AirFlow Parked (IAC)
Idle AirFlow (Running AirFlow)
Throttle Follower AirFlow
Air Adjustments do effect overall AFR.
FWIW.
