1 OR 2 Wideband O2
any of the AFTERMARKET Wideband O2 controls support DUEL SET UP?
provided your injectors are all flowing about the same, 1 side is good enough, keep an eye on your short and long term fuel trims, and see if either side is out of balance of the other. If so, then you will want to swap the sensor, and make sure both banks are good.
If running a high hp setup, on stock rails, i would run the o2 sensor on the passenger side bank, as that side tends to go lean first due to the rail design.
Ryan
It may be different with badass NA setups or FI, but I would speculate they arent risking using stock rails at that point either, where Nitrous you get more out of them, even using a dedicated fuel system or not.
Curious about it, not calling BS, just sharing my experiences.
Bfly, I have been wondering about the same thing since I am getting ready to get HPT, I was wanting to make a switch box, like used for printer sharing. Although you can use the LTFTs to verify they banks are in synch, I would be curious if there is a difference, even the slightest in the LTFTs as to what it equates to in wideband, e.g. bank 1 LTFT -6.3 /// bank 2 LTFT -5.9. One bank may be running at desired 13.1:1 on street, where the other is running 13.8 or something. I worry about for the spray mroe than anything else.
Charlie
When I went FI, I also gutted that damper and increased fuel volume and pressure. My driver side went leanest.
It seems several factors can influence this.
bfly- What kind of setup are you planning/do you have? If you have the extra cheddar, I would say its nicer, but its really not that needed (I'd go dual WB if it was less $).
