Help
Old Dec 26, 2004 | 07:06 PM
smlss's Avatar
Default Help
I,was trying to program my 98ss with my hypertech programmer,and my car battery went dead. I charged my battery & tried to continue the programing but the hypertech says code 6 call hypertech,but they are on vacation unti Jan 3. Mean while my car just cranks over and will not start.Any advice would be greatly appreciated.
Old Dec 26, 2004 | 07:18 PM
foff667's Avatar
LS1TECH Sponsor
you could probably get it reflashed & try again but im not even sure that would work 100%
Old Dec 26, 2004 | 09:27 PM
slow's Avatar
your going to need a reflash from the dealer, or somebody local with hptuners.
What kind of transmission do you have? If its a M6, send me a pm, i have a spare 98 pcm i could help you out with.
Ryan
Old Dec 26, 2004 | 09:33 PM
Another_User's Avatar
Eeew...will his Hypertech be locked now? Or if his PCM (new or reflashed) has the same VIN, will he be ok?
Old Dec 26, 2004 | 10:04 PM
horist's Avatar
hmmm... good question...
I would think that as long as it's the same PCM and same VIN... he could select to restore back to stock ... then reapply any HPP3 settings
Old Dec 27, 2004 | 08:09 AM
smlss's Avatar
Thanks for the information!
Old Dec 27, 2004 | 04:22 PM
slow's Avatar
you will need to call hypertech, and itim 99% will need a reset.
Just remember, your the first owner of the product.
Ryan
Old Dec 27, 2004 | 08:01 PM
Ryan
Yes yes. Definitely the first owner. Or else they will tell you to **** off.
Old Dec 27, 2004 | 08:47 PM
smlss's Avatar
Ryan
So all I need to do is call hypertech,and have them reset the programmer?
Do I need to have my computer reflashed?
Old Dec 27, 2004 | 09:37 PM
PCM reflashed, and then try to use the Hypertech again. If it does not work, then call Hypertech, tell them you are the original owner, and have the programmer reset.
Old Dec 27, 2004 | 09:41 PM
GrannySShifting's Avatar
pull all the fuses, unhook bat, and let it sit for some hours. try to reload the program. sometimes itll catch it
I had a couple people do this with their hypertechs, I just hit them with a full reflash with my software and so far everyone has worked fine
