Exactly what does HPP3 do.
1. Advances the High Octane Spark Table by about 3 degrees on the 87 Octane Tune
2. Advances the High Octane Spark Table by about 4.5 degrees on the 91 Octane Tune (or 1.5 additional degrees over their 87 Octane Tune).
3. Gives the user the ability to adjust shift points, Tire size, rear axle ratio, etc.
Most of the parameters of the tune calibration are unchanged which makes sense as they are designed for a stock engine which is fairly well set up from the factory. I did not see that any changes were made that effect mixture/fueling.
Hope that this helps.
Does anyone want to buy my Hypertech 30005?
Steve
Steve
Exactly what I found. It only really adjust high and low tables. There was another table it messed with but i cant remember off the top of my head. Mainly what you said is what i found and did this on a 03 5.3L serria
Hence the reason Power Tuning helps some cars and others run slower... some cars are running just perfect AFR ... any leaner and they get knock... you lean a car out and add timing ... there's a good chance of getting knock...
Now I remember it affects the PE table also. And like horist said every car responds different from what I have seen.
