Why do LS1 and LS6 PE Tables differ so?
-Gary
-Gary
-Gary
The Z06 (LS6) was top-of-the-line, narrow performance
enthusiast market where max HP was more important than
the occasional pinging problem and the drivers are made
of money and will pay to tweak it up.
The LS1 was mass-market, you get a few tens of thousands
of these coming in for warranty beefs on account of pinging
under load, you're screwed (if you're GM).
That, and if the LS1 made the same numbers as the LS6 then
corporate Hell would freeze over. So da Man be holding us down.
The LS6 profile is more like what I'd expect for a performance
tune, I think the declining commanded AFR at higher RPM is
probably covering fuel fade (I have seen other places, the
idea that you want fatter at midband (for torque) and lean
it out a bit - relatively speaking - up top for HP. You need a
faster burn rate at high RPM to get it all done in the power
stroke, and your spark set to put in the right place.
The 'vettes also have that funny air bridge deal that biases
airflow centrifugally and this probably accounts for some air
flow side differences, that and the lack of screen on the MAF.
-Gary
after looking at the ybody and fbody pe table, its obvous the Vette has the better tune. However I thought more fuel helped torque down low and leaner at high rpm's helped it combust faster. Would a 180 of the vette graph be a good starting point for a tune? say start at 11.5 and work up from there? I know many factors would be affected. I'd probably have to pull a degree or two of timing up high with a leaner condition.
No, GM wouldn't make a car heavier to de-tune it.... They struggle enough with CAFE and mpg ratings as it is, without making the car intentionally heavier...
Now turning the PE and timing down, that's very likely. My reasoning, about the doors, is that the car is a 2-door coupe, with a back seat (unlike the Vette), which necessitates longer doors. If GM wasn't weight conscious at all, they probably would have slapped sheet metal on there.
I wasn't aware of the better LS6 factory tuning (before reading this thread); It's pretty interesting to consider. I agree with you guys that GM was just trying to cover their ***. I believe that they think of Corvette owners as true enthusiasts, and the f-body guys and gals fit all categories from secretaries, to pimply-faced first-time car buyers, to enthusiasts--a nice safe tune for the masses.
