SES Lights
Old Mar 26, 2005 | 09:44 AM
2000Z28M6's Avatar
Default SES Lights
Should I be worried I have not yet a SES light or any kind of code. I removed EGR, AIR and no SES lights or codes. Now Im running LTs and NO SIMS and still no SES light? Is my SES light out ? ANy suggestions besides getting it on a full dyno tune with a Scanner.
Old Mar 26, 2005 | 10:25 AM
Green Thunder's Avatar
Does your SES light come on then turn off when you first turn your ignition switch on?
Old Mar 26, 2005 | 11:20 AM
2000Z28M6's Avatar
I dont see it on when I turn on the car. Ive never seen it so....unless its the service engine light. Everything else on there lights up. Is it SES what i look for? Sorry for my lack of knowlegde on this....
Old Mar 26, 2005 | 11:26 AM
Yes .. S=Service E=Engine S=Soon... Some only have Service engine some have a pic of an engine..
Old Mar 26, 2005 | 11:28 AM
2000Z28M6's Avatar
Well then yea it lights up fine when you first put the key in. So should I be worried It has not been triggered?
Old Mar 26, 2005 | 12:05 PM
2001NBMZ28's Avatar
If you don't have access to a scanner you could try resetting the PCM, then pull the AIR PUMP fuse - that should throw the SES light (P0412) after the second consecutive cycle failure. If it doesn't illuminate somethings wrong. Any chance the air, egr and rear 02 codes were turned off?
Old Mar 26, 2005 | 12:18 PM
2000Z28M6's Avatar
I dunno I bought the car used. Resetting the PCM probably wont help because I never got a SES light when I first pulled the egr like last year. Im kinda worried cuz I thought headers without simms would trigger it for sure. I will try to get a full dyno tune in bout a month or so. Car is running fine. I can smell shes rich, but that was expected.
Old Jul 31, 2006 | 01:37 PM
wickedwarlock's Avatar
if you turn the key on, before starting the vehicle, all the lights should come on, it's a bulb check.
It's possible that the ses bulb could be blown. If you see it come on than go back off, you probably don't have any problems. But the lamp should come on prior to starting it up.
