A4 to M6 swap what computer?
Old Apr 5, 2005 | 06:08 PM
Michael Ozorowsky's Avatar
Default A4 to M6 swap what computer?
Can I reflash the ECM with HP Tuners when swapping my car from an A4 to M6 or do I have to replace ECU?
Old Apr 5, 2005 | 06:43 PM
horist's Avatar
yes you can reflash, grab a M6 .bin file and do a full write (taking hte necessary precautions, car battery charged, cable connections good, etc...)
Old Apr 5, 2005 | 07:14 PM
gameover's Avatar
you DON'T need to do a full write (Rewrite Entire VCM) for a trans change, just flashing the M6 calibration is fine as the Operating systems are the same.
Again, the normal "Write VCM" will work fine.
Old Apr 5, 2005 | 07:36 PM
wait4me's Avatar
you have to do a full rewrite if the operating systems are not the same between the two files you are wanting to use, If you have the same operating system on both files then you are ok... Sometimes finding a m6 file from a matching os system is a pain in the butt to do.
Old Apr 5, 2005 | 07:46 PM
gameover's Avatar
yeah but remember to change the VIN and if serial VATs is used you need to relink the BCM as well if you take this option.
Chris..
Old Apr 6, 2005 | 12:52 AM
horist's Avatar
good info! I was under the impression you had to do a full rewrite...
Thanks Chris
Old Apr 6, 2005 | 11:03 AM
SMOKINV8's Avatar
Chris..
Any additional info for relinking the BCM?
Old Apr 6, 2005 | 05:50 PM
gameover's Avatar
See the help file under, Edit -> Pro Tuner Functions.
