Who tunes with only STFT's?
If you do, what is the CORRECT way to shut off the LTFT's so they dont learn anymore?
Also, when in the tuning stage do you just reset fuel trims and adjust VE table after every 20 minute drive since the STFT's update continuously?
When you were done tuning the STFT did you turn back on the ltft's? Were they the same?
The LTFTs need to be turned off in the PCM to use STFTs for SD tuning.
In HP Tuners , under Engine -> Fuel Control -> Open & Closed Loop
Long Term Fuel Trim Enable, set to off
LTFTs will no longer be used and only STFTs will be used
What horist said.
Make sure your LTFT's are within +/- 10 before turning them off and using your STFT's to tune. This is the method I use, and lemme tell ya, it's a hell of a lot quicker and less of a headache.
When using STFT's there is no trim resetting to be done, as STFT's are not "learned". They are a second by second fueling adjustment that the PCM uses based on what the O2's are showing. I will typically log for 10 minutes, then adjust the VE table, then log another 10, etc. Using this method, I was able to get my VE table adjusted so that all my STFT's average between +/- 3 in less than an hour.
When you're done, just re-enable your LTFT's. Once they learn out, they should all be very close to 0.
Originally Posted by 99whitews6
Can I just tune with the STFT's and not using speed density? Just normal maf tuning.
if you turn them off w/the scanner , they'll turn back on by default... but if you turn them off in the editor, (turn off, flash PCM) they'll stay off until you reflash with another tune that has them turned back on
I haven't tuned my TA w/this in a while (damn winter, and now she's sans a transmission) but when I was doing it, they would stay off indefinetly until I turned them back on (using the editor) ...
I've been running with the LTFT's disabled for weeks now. I suppose I'll turn them back on again someday, but right now I'm having too much fun playing with my VE table.
Is it a bad idea to tune SD with no MAF from ltfts when starting with a completely new top end (h/c, headers, exhaust)? Should you use the stfts? With ls1 edit how would one go about this? I have EFI Live but no bi directional controls. Thanks.
Not sure how you would go about it with LS1 Edit, since I've never used it.
alright, i am currently tuning my LTFTs using VE(maf is still connected). I dont have time to go SD till the weekend because it seems like there are multiple things to turn off and adjust to go speed density.
After cam install I logged LTFTs(averaged) and the histogram showed values between 0-7. I then increased the primary and secondary VE accordingly and reset the fuel trims. I have driven about 90 miles since and I just got back from a 30 minute log. Now the histogram shows values from 7-10 in those same regions.
Shouldnt the values move closer to zero since i increased the VE table?
Also, the STFTs from this same log are now closer to zero than before (all values are now -2 to 3 with a lot of 0's). Why did the STFT values go closer to zero and the LTFTs go farther away from zero?
Is the car ok to drive until the weekend when I have time to work on it? (i have no KR).
Second, STFT's close to 0 are just showing that your LTFT's have been learned. LTFT's and STFT's work like this: Say the value of one cell in your VE table is 70. Now, let's assume that the "actual" value of this cell should be 85. When the PCM falls into this cell when you are driving around, your 02's will report a lean condition, causing your STFT's to go to around +15. Now, when the STFT's change the fueling by 10% or more for longer than 10 seconds, the LTFT's begin to compensate by swinging towards +15. How quickly this happens depends on how long the engine operation falls in the cell in question. If it's a cruise cell, then the LTFT's will reach +15 very quickly, at which time the STFT's will drop back to around 0, since the LTFT's have adjusted fueling to compensate. If you happen to log it before it is fully learned, you might see an LTFT of +10, with an STFT of +5. Of course, the math isn't always nice and clean like this, but you get the picture. This is what makes tuning with STFT's alone so much easier; you don't have to wait for them to be learned.
Your car is safe to drive around. It's just showing that the "actual" fueling is 7-10% off from the "mapped" fueling. The PCM has a pretty big range of adaptability with both the LTFT's and STFT's.
And there's actually not much to going SD. Just unplug your maf. You can disable the SES light for the codes it's going to throw if you don't want to see it on. Then just copy your High Octane spark table to the Low Octane one, since the PCM reverts to it if the maf fails. Otherwise, just log and adjust your VE table like you've been doing.
WOHOOO
So I unplugged my MAF during my lunch break today and went SD to tune. Before I unplugged the MAF my LTFT's were about 7-11. After I unplugged I watched the STFT's and as soon as i started it up all the values went around 20 ish. I drove, adjusted, drove, adjusted, on and on for about 45 minutes and now all the STFT's are -3 to 2. Car likes me noW!!!!!
So whats my next step?
WOHOOO
First off, re-enable your LTFT's. It wouldn't be a bad idea to log and check them after a week or so just to see where they end up. Shouldn't be any surprises, but it never hurts to double check.
If you plug your maf back in, it's going to queer all your LTFT's again. Then you get to scale the maf table until they come back into line. Conversely, you could remove it all together and turn it into a flower pot or something. Whatever you decide, after that it's time to take it to the dyno and do some WOT tuning!
