For all the SD-VE-MAF doubters out there...
Haven't touched my tune in 2 months now and still holding strong... Today we hit the upper 80s in H-Town... I wonder what 90s will bring...
And Houston has some serios Humidity (I can't stand Houston weather). Nice work, do me a favor when it hits 90-100 repost the results then. But i'm sure you'll end up changing it some before then so I guess it wouldn't be 100% valid results. None the less Very Nice!
damper for the MAP sensor, to keep manifold
pulsation from kicking it around? Be interesting
to put a 'scope to the MAP sensor output and
see just how badly the value is jumping (to be
caught at various points by PCM sampling).
BTW, you only got up to 3600 rpm going to the grocery store? your not trying
The MAF takes over at 4k, right? So to show us how your MAF table is doing, we need to see some redline runs.
Over 4K I won't get any trimming anyway cuz i'll most likely be in PE mode but yes in higher RPMS it's ALL MAF. I guess one of these days I could crawl back under my car and get the wideband back in and check a WOT run... Damn you...
So if your results hold up, then that means all we have to do is get it real close on VE then all in one day finalize the VE and calibrate the MAF and sense the MAF is always primary (most of the time) the tune should not really need any further adjustments until we modify something in the air track that would require recalibration of the MAF?
