can't rid the ping
Is there any audible detonation? yes-reduce timing in effected area / add fuel
No Audible knock: Is there a pipe banging, clogged CAT, spark plugs, oil in combustion chamber? Correct as needed, if no....Use race gas mix to determine if its false KR and retune accordingly.
I currently had 1-2* KR during qtr passes, but not in the same cells each run, off by a few during the shifts etc. I reduced timing from 31* to 22* in increments of 2* and each time the KR was still there. I wouldnt be able to hear KR if the engine was about to blow, so I went timing, then looked at fueling. Both good. Stood outside the car today and heard the pass. pipe after the X banging! Damn it. Found my source.
My fuel pressure is fine too at 60 psi.
The reason I asked if 17* is what's programmed versus what's logged. There is a optimal timing table in EFI and in HPT it's called average mean best, I think. No matter where I set my timing in High Octane, under load my timing reverts to the Optimal table. In my case that's 3* more.
Anyone know what the trigger for the switch is?
The table is in Spark Advance and is named Mean Best Timing.
thanks, im going to check that table out
for Optimal and High octane, would have an adverse affect on anything else. The definition in EFI is:"This table is used as a reference for what would be best timing, which is then used for various torque calculations." Kind of vague. But, my car is selecting the Optimal Table at WOT anyway, so it seems like a good idea.
so yours goes into the optimal at WOT? from what i can tell all my numbers are comming from the high octane table.
here is what was in hp tuners
Mean Best Timing
Max Torque Timing vs. RPM vs. Cyl Air: Theoretical spark advance that delivers maximum torque. PCM torque calculation routines reference this table when estimating current engine torque output relative to theoretical maximum. We do not recommend modifying this table.
Mean Best Timing
Aria
Aria
