Dynamic Cylinder Air Chat
Also have you taken note of what FTC you are in when the the problem is occuring?
Another_User- Do you have convenient access to a wideband O2? I'm interested in whether or not your O2's are locking at max because of an actual rich condition, or because of some other problem, perhaps something internal to the PCM. Which brings up another question: Do you have a buddy you could swap PCM's with?
electronics issue with the MAF. Like EMI or something
(I read that in the Helm manuals, the MAF or the PCM's
reading of it can be bothered by electrical noise, like
from injector harness or plug wires). The HPTuners log
can only show you the data that comes over the OBDII
and that is "decimated" by a factor of 8 (12.5mS main
data cycle but 100mS report cycle) so you might just
not see the thing that really set off the problem unless
you catch a lot of these events. You might look at the
MAF frequency and see if there is anything twitchy
about that. Like supposing you were at a MAF frequency
that was close to your ignition or fuel injector pulse
freq, maybe you get an occasional funky beat.
Or something.
Maybe it's just bad MAF karma, considering your avatar and all...
http://users.adelphia.net/~someoneelse/05MAY05.hpl
If you look at your STFT's and compare it to Commanded EVAP, you can see that they mirror eachother perfectly. I think Commanded EVAP changes with fuel trims so as not to throw off fueling by letting in too much fuel vapor. You'll notice that when your STFT's drop to -40, the Commanded EVAP % drops from around 50 to about 30. When the PCM is pulling fuel using trims, I believe it is also telling the EVAP system to cut back on the amount of fuel vapor it's allowing into the intake. I think that if the EVAP system itself was causing the dive in trims from allowing in too much fuel vapor, you would see the Commanded EVAP % rising when your trims drop, instead of falling. Also, I'm not sure that even if the purge solenoid was stuck all the way open that the additional fuel vapor would be enough to result in STFT's in the -40 range. I am also unaware of any difference in EVAP operation in MAF vs. SD mode.
But, like I said, I'm not exactly well versed on EVAP system operation. I hope I'm wrong, because it'd be great to be able to narrow it down to the EVAP system.
protocol anyway, why not say "screw the EVAP" and
call it weight reduction?
But anyhow, like you said, do alot more logging and see if the problem recurs.
I have a question about 02 sensors and how to tell if they are bad. I do not think mine are bad but mine do not look like yours. Mine Run right on top of each other is that bad or good. Your at the top are kind of inbetween each other. Do you kind of know what I am saying?
I hope that you guys do get this figured so I can go in and compare this to other logs and least I will know what the problem is if I ever see it. I definently will not for get this post
If anybody looks at the second log I posted for information, please watch the EVAP PIDs because I was turning things on and off while I was testing, so it does not fully reflect a real situation while only your PCM is in control of everything.
Good luck, and keep us posted on what the log shows!
. Mine is gone
