Dynamic Cylinder Air Chat
Charlie
You bring up a good question about dynamic cylinder air. I have a couple of ideas about this, but I'm going to sit on them overnight until I can try some things out on my car tomorrow to prove/disprove what I'm thinking about.
(density) while MAF airflow embodies the RPM (speed)
as well so would diverge from CylAir, by that dimension.
I've seen remarks that CylAir also has some smoothing
done to it. I do not know the entire algorithm (or even
much at all).
much at all).
Looking at the DA waveform, we can see how it ramps up to peak airflow, and ramps back down to idle airflow, with a gradual slope during the throttle transitions. Conversely, the MAF airmass waveform jumps up to peak airflow and drops back down to idle airflow with almost no slope at all. It's almost like turning a switch on and off. Airflow is of course going to gradually increase to peak and gradually decrease to idle like shown by the DA waveform, so the MAF waveform is showing us graphically the inability of the MAF to follow throttle transitions with an acceptable degree of accuracy. Looking at the peaks of both waveforms, we can also see that the MAF airmass peaks sooner than the DA.
Now, if you look at the DCA waveform, you can see how the PCM is smoothing/blending the MAF airmass reading with the DA calc. The DCA waveform is showing smooth transitions, like the DA waveform. If you reference the DCA peak with the others, you will find that DCA is peaking in between the MAF airmass and DCA peaks, although it peaks (in most cases) much closer to the MAF airmass peak. This would seem to show that the PCM is relying most on the MAF airmass reading, which it "smooths" using the DA calc during throttle transitions which the MAF just can't follow accurately. This is of course not a new concept. We're just seeing it in action, so to speak.
My stance on the matter is that your VE table is correct. Your trims during SD operation prove this. The Dynamic Airflow calc is correct by definition (as long as your inputs are good), so you can rule that out too (unless you inputs are bad
). So, that leaves the MAF (most likely I think) or the actual filtering applied to the MAF signal by the PCM, as dictated by the data entered into the Dynamic Airflow tab in HPTuner. Personally, I think the engineers at GM probably did a pretty good job at setting up that particular dynamic filter, another reason why I think it's the MAF.Could you post up the logs that show these trim problems you've been having? Or email them to bluetorp@yahoo.com ? It would help me understand a little better the problems you're having.
I observed during my logging that DCA followed the MAF airmass reading completely during steady airflow, i.e. at idle, or cruising. During throttle transitions, it still followed the MAF mostly, but DCA was "smoothed" to compensate for the MAF's inability the accurately follow the changing airflow. I find that the MAF airmass reading is still the most telling factor. Are your fueling issues happening at constant throttle, or rapidly changing throttle transitions? The MAF airmass reading is only filtered when the PCM detects a throttle transition, and it is filtered to the extent dictated by what MAP vs. RPM zone the engine is currently operating in.
http://users.adelphia.net/~someoneelse/14APR05.hpl
Since it's happening at constant throttle, you can eliminate the DA calcs because they are not being applied to the MAF signal since no throttle transient is occuring. The MAF signal looks good, nothing crazy going on there.
Your STFT's are diving down to -40 because your O2's are locking super high at around .900. The real question is why they are doing this. Like you said, it's probably not the O2's themselves since they are both being affected in the same way. Another thing that I notice is that your O2's never go into a good pattern (sine wave). They are showing a very jagged and irregular waveform. Have you modified anything that you can think of that might be affecting your O2 operation?
Do you have a log that shows what DA and DCA are doing when your trims take a **** like that?
Also, do your O2's drop into a good sine wave pattern at cruise when running SD, or do they look the same as they do in the log?
I can see no reason for the O2's to be reading like that. MAF airmass and DCA are steady, as well as injector pw, and everything else (MAP, TPS, etc.) as well. What's really strange is that it only does it with the MAF plugged in. Hmmmm...
Those O2 waveforms just look crazy to me, aside from locking at .900. I'm attaching a pic of what mine look like at cruise. Correctly operating O2's should look something like this.
I have been pondering this issue for awhile. The only thing I can think of that could cause my trims to go this rich without an increase in injector pulse width is a malfunctioning EVAP. You wouldn't happen to know if EVAP functions differently in the event of a MAF or similar failure? Tomorrow I am going to log a run with EVAP forced off and see what happens...
At this point I'd be testing anything and everything!How consistent is this problem when running the MAF? Is it at all possible that it may just be coincidence that it's only popped up during MAF operation and not SD?
