Too Rich
Old Aug 3, 2005 | 05:19 PM
mtrhed's Avatar
Default Too Rich
Have a 2000 Camaro SS with 7 PSI Procharger,42lb injectors,walbro pump,Off road y-pipe,Diablo sport tuner...my problem is car is runnning extremely rich....everytime I hammer on it spits out black smoke,coughs,eventually cleans itself out and goes like hell...but the initial coughing is terrible.I have removed tune and reinstalled several times nothing changes,just driving around car runs fine...when you start to hammer....cough!!!! Any suggestions???
Old Aug 3, 2005 | 06:50 PM
TAQuickness's Avatar
Do you have a scan tool? If not, I would suggest picking up a copy of EFILive so you can start logging what your car is doing.
www.efilive.com
Old Aug 4, 2005 | 11:12 AM
mtrhed's Avatar
I have my diablo sport...it does some diagnostics...but...efilive is probably the ticket.
Old Aug 4, 2005 | 11:15 AM
mtrhed's Avatar
Anybody in Indiana tuning these cars???
Old Aug 4, 2005 | 11:21 AM
I'm not very familiar with Diablo sport, but you may want to consider EFILive Flashscan or HPT for your tuning needs. There is a lot in your tune you will need to modify to achieve the full potential of your mods
WS6FirebirdTA00's Avatar
you can log the o2s and see what mV they are reading, anything over 920 SHOULD be rich
Old Aug 4, 2005 | 11:37 AM
2xLS1's Avatar
You can't just put 42 lb injectors on a car without changing the IFR table, something your preditor is not doing. You will continue to run extremely rich until you do.
Old Aug 4, 2005 | 11:42 AM
unless he got the predator tune with changed ifr values
Old Aug 4, 2005 | 04:39 PM
mtrhed's Avatar
Predator came with Procharger setup.It was working good,I then changed tire sizes and everything went crazy...returned to stock,re-installed tune several times...now RICH..I am Lost.
