lm1 question
Old Aug 29, 2005 | 09:03 PM
SLP4CamaroSS's Avatar
Default lm1 question
hey does anyone know if u can get the lm1 and hook it up to any car and get the afr?
Old Aug 29, 2005 | 10:08 PM
anyone i have the basic lm1 kit
Old Aug 30, 2005 | 05:55 AM
Brent@LPE's Avatar
I have a lm1 it comes as complete stand alone kit does not interface with the "car"unless you want it to....you could test the A/F of your lawnmower if you like!
Old Aug 31, 2005 | 10:41 AM
so u just can hook it up and get the afr then right. and also do you have to convert something in hptuners to get it to work with it so u can read it in the hptuners scanner
Old Aug 31, 2005 | 10:44 AM
foff667's Avatar
LS1TECH Sponsor
if you have it hooked to hptuners and your hooking to say a honda i dont believe you can view the readings through hptuners...you'd be better off using the lm1's supplied software.
Old Aug 31, 2005 | 11:52 AM
the basic kit is ok to view all that stuff right on other cars
Old Aug 31, 2005 | 12:04 PM
foff667's Avatar
LS1TECH Sponsor
yah...because its not connected in any way to the car...your just plugging it into a bung in the exhaust & reading what it says.
Old Aug 31, 2005 | 12:15 PM
makes since have a question when tuning with hptuners and your tuning a car that just put on header you adjust the ve tables am i correct?
Old Aug 31, 2005 | 12:46 PM
foff667's Avatar
LS1TECH Sponsor
there are 100 ways to tune...for headers I'd do some ve & pe tuning though...if no cats I'd also delete cot
