where to put o2
Old Sep 2, 2005 | 10:43 AM
SLP4CamaroSS's Avatar
Default where to put o2
where do you guys put the o2 bung at under your car to measure afr at?
Old Sep 2, 2005 | 03:05 PM
anyone
Old Sep 2, 2005 | 03:09 PM
DrX's Avatar
DrX
Ideally: ahead of the cats, less than 30 inches from exhaust port, drivers side according to Dynojet and RWTD. Sensor should be mounted above horizontal to prevent condensation from accumulating on it.
Old Sep 2, 2005 | 03:56 PM
jimmyblue's Avatar
Moderator
In the I-pipe by the trailing edge of the passenger's
door, where I can get at it without jacking the car
up and the cable can come inside short & snug. I
use mine only occasionally fur tuning, not full time.
My cat shells are empty, so no worries about the
gas mixture being modified. WBO2s want to not be
-too- close to the exhaust ports because they need
the heater, not EGT, to be in control of operating temp.
Old Sep 3, 2005 | 06:42 PM
anybody else
Old Sep 3, 2005 | 06:43 PM
i still have my cats
Old Sep 3, 2005 | 08:23 PM
TAQuickness's Avatar
they answered your question
Old Sep 3, 2005 | 11:54 PM
racecar's Avatar
No cats, I put it 4 feet back of the headers so the sensor won't get burnt up.
I would put it as far back as you can, they warn you about that sensor getting too hot.
Old Sep 4, 2005 | 12:34 AM
forget this im hollowing my cats make it easy and put it whre jimmyblue said
Old Sep 9, 2005 | 12:03 AM
DrX's Avatar
DrX
I see RWTD has corrected that to passenger side(bank 2) which is where I placed mine.
https://ls1tech.com/forums/showthrea...highlight=bung
Old Sep 9, 2005 | 12:35 AM
horist's Avatar
FWIW ... I really don't think that it matters if it's pre or post cat in most cases...... for years ... you go in for a dyno tune.. they stick that probe up your cars *** for wideband... guess what .... it's not going past the cat heh...
There was also a post on an aussie ls1 board where someone tried pre and post cat and the differences were negligable ....
If I had cats on my car I'd try it.... If I had an I-Pipe I'd try thta way too heh
Old Sep 9, 2005 | 09:38 AM
2002z28's Avatar
i put my wideband o2 after the cat. dynotech eng told me to compensate .4 richer on my gage. my car was tuned with a wideband after the cat and it runs like a champ.
justin
