A/F ratio with F.I.
Old Sep 16, 2005 | 09:30 PM
shawn_c992001's Avatar
Default A/F ratio with F.I.
I'm running ~5psi with a ratio of 14.7 is this good or bad? Would around 12 be better?
Old Sep 16, 2005 | 09:59 PM
ujslost2's Avatar
Yes i would definetly run at least 12.0 a/f at wot. 14.7 is way to lean for a boosted car...
Old Sep 16, 2005 | 10:19 PM
slow's Avatar
you want to be richer when at wot, but part throttle, the pcm will command stoich, which is around 14.7
Ryan
Old Sep 17, 2005 | 09:55 AM
soundengineer's Avatar
Ryan
unless you put the car in Full time Open Loop
then it will command exactly what you tune it to
I liek to tell the pcm 13:1 for Part throttle and then 11.5:1 or 11:1 for WOT...... sometimes richer depending on Boost
Old Sep 17, 2005 | 10:41 AM
ESR's Avatar
ESR
LS1TECH Sponsor
the car will try to maintain 14.7 during regular driving...........you want no higher than 11.8 ...........11.5 on a dynojet 11.8 on a mustang.
Old Sep 17, 2005 | 11:10 AM
slow's Avatar
There is no benefit to being richer at part throttle that I have ever seen on a newer vehicle I'll do that on a fox body, to make then run smoother.
Ryan
Old Sep 17, 2005 | 11:28 AM
Ryan
can help with tip in knock by having part throttle richer
Old Sep 17, 2005 | 12:37 PM
LS1-450's Avatar
What I like to do is tune for 14.7 under part throttle while in vacuum to maybe -5 inches of water. Once @ -4 in. through 0 psi & up to 4,000 RPM maybe 13.5 & from above 0 psi through 5 psi no more than 13:1 as long as there's no ping (knock) & the car is making power. Somewhere between 12.5 & 13:1 should be OK as long as timing is not advanced enough too cause knock @ WOT. It's a balance between timing & pre-detonation under boost. For sure 14.7 @ WOT under boost is way too lean. Good-luck.
Old Sep 18, 2005 | 09:43 PM
hellbents10's Avatar
LS1Tech Sponsor
Right I tune afr to cylinder pressure. At around 0 boost I like to see 12.8-13.0:1 at wot. Then as boost comes in I will go down to about 11.8:1, for a lot of boost on pump fuel I will go even richer.
Old Sep 18, 2005 | 10:08 PM
What about the timing 28* at WOT too much?
Old Sep 18, 2005 | 10:31 PM
LS1Tech Sponsor
I would sy thats a bit much for even 5psi. Now lets say your iat was like 60deg with race fuel then it may be fine. How much kr are you seeing. 28 is good in vacume or up to 0psi but coming into boost you should be seeing a little less then that.
Old Sep 18, 2005 | 11:47 PM
slow's Avatar
28 at wot, on street gas is very agressive imho on a lsx engine.
Ryan
Old Sep 19, 2005 | 07:08 PM
What would be a good starting point?
Old Sep 20, 2005 | 02:22 PM
John_D.'s Avatar
I was running 28 (accidentally) and blew 3 pistons in about 3 seconds. You should be somewhere around 14-16 degrees, then adjust up or down from there.
