questin about VE table
Old Oct 7, 2005 | 10:15 PM
WS6FirebirdTA00's Avatar
Default questin about VE table
in my ve table, 2000 and 2400 rpm columns are about the same. if you look at the graph, it looks like the graph is offset. i am just wondering why this would be? could it be just getting in the power band of the cam does some funky stuff or what?? ive been wondering about that for a while, i can try to get a graph off the lap top if you wanna see it
Old Oct 8, 2005 | 08:36 PM
Patrick G's Avatar
LS1 Tech Administrator
On my VE tables, I have a slight dip from 2000-2400 rpm, then it starts climbing again. Is this what your VE table does too? Since we have similar cams, it wouldn't surprise me.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 8, 2005 | 09:05 PM
yeah thats exactly what it does
Old Oct 9, 2005 | 05:02 AM
TAQuickness's Avatar
how bout a pic?
Old Oct 9, 2005 | 07:19 AM
Gman2002Z06's Avatar
With the G5X3 cam, alot of guys were posting dyno results that showed hp dips in the 2500~3500 rpm ranges...I did not dyno after my cam install, but I could notice the flat spot in the same rpm range with my car...Which led me to the following...
I haven't done SD tuning, but after my cam install and still using the stock VE table...I had dead spots below 4000 rpms...By this I mean the following...
I would put the car in 3rd gear at about 1200 rpms, I would go WOT and just feel how the car was accelerating...It was very sluggish and uneven below 4000 rpms, then it would pull really hard above the 4000 rpms, felt as if 2 more cylinders would kick in...I started messing with the VE table...Mainly I began to increase the values...What I eventually ended up with was a very fat VE table down low...Values in the 100~120 range at 105 kPa and 1200~7000 rpms...
But the results were the following...Doing the same acceleration test as above, the car pulls very strong down low, with a very smooth transition at the upper, above 4000 rpms, rpm range...Also, as a by product, my KR at light throttle and low rpms was reduced considerably...
Throttle response is excellent...I'm not sure the car would even run without the MAS, but it sure runs good the way it is now...
Peace...Gman
Old Oct 9, 2005 | 07:40 AM
Patrick G's Avatar
My car now pulls beautifully from 900 rpm on up. Tuning all areas of the car has done wonders.
Old Oct 9, 2005 | 08:37 AM
HumpinSS's Avatar
G5x4 here and I have that dip also it was also there with my Fm13. Most of the vehicles i tune have that dip if they are cammed. I think its a combination of the cam and the motor that make that dip. Ive tried smoothingit out but the WB keeps telling me its rich in those areas so i end back up with the dip in the table
Old Oct 9, 2005 | 08:40 AM
Patrick G's Avatar
Good to know I'm not alone, LOL. I've tried smoothing the dip, but mine too keep showing rich. The dip stays.
Old Oct 9, 2005 | 09:05 AM
HumpinSS's Avatar
Yeah i was kinda baffled at first myself because everyones cammed cars who ive seen pictures of the ve table was smooth in that area. I though it was only me until i started seeing more occurances of it. I agree the dip stays
Old Oct 9, 2005 | 09:07 AM
GuitsBoy's Avatar
I have the same, although I dont remember if it was between 2.0K and 2.4K since I dont have my current bin with me. I know there is a dip in my VE. Even my stock VE had a bit of a dip as it was tunes from the factory.
Old Oct 9, 2005 | 11:43 AM
bowtieman81's Avatar
I would like to see a pic of you guys VE table, or better yet send me the table in excel. I have a problem exactly like Gman described above when flooring it at 1000 rpm and the engine slowly coming to life. Mine feels doggish below 3500 rpm or so, and I know that should not be the case. Right now with my current tune the car wont spin the tires in first gear until about 3800 rpm!? From what most guys say that have my cam it should roast the tires easy. Drag strip experience backed this up, when launching the car it would bog every time, even at 2500 rpm.
Any help would be appreciated guys, I have had a hell of a time dialing in the VE table below 2000 rpm.
Old Oct 9, 2005 | 11:56 AM
HumpinSS's Avatar
It aint no picaso but it works
G5X4 full weight M6 went 11.77@120.1 with a 1.80 60' and 11.64@119.70 with a 1.66 60'
Old Oct 9, 2005 | 12:16 PM
thanks Humpin. A couple questions: is your car cam-only with all the bolt ons? Also, can you put those VE values in excel and shoot me an email? I can't quite view the graph with HPtuners in the same view you posted here.
email: bowtieman81@aol.com
Old Oct 9, 2005 | 12:19 PM
Humpin, I would also be very interested to see your FM13 table, for obvious reasons
Old Oct 9, 2005 | 12:21 PM
HumpinSS's Avatar
Yes it sure is heads havent been off the car full bolt on including fast 90/90. Sure i will send it soon
Old Oct 9, 2005 | 12:26 PM
HumpinSS's Avatar
FM13 table is long gone. Do you have a WB or are you trying to tune with your trims. If its the latter this is why you may be having such a hard time with low throttle driving. After using a WB for more than year and some change I will not be going back to narrow band tuning anytime soon the stock o2 just dont do it for me.
Old Oct 9, 2005 | 12:35 PM
Only wideband, and it was working great for mid-upper rpms. I am currently in SD mode for tuning, and I may stay in speed density for good if weather proves not to affect me much. My tuning efforts have worked good for mid-upper rpm ranges. My LT trims are dialed in perfect, its just the low rpms that is giving me trouble.
I think I need a little more idle tuning, and definitely some more 1000-2000 rpm work. I am also trying to cure my low rpm, low load bucking.
Old Oct 9, 2005 | 01:48 PM
Patrick G's Avatar
Your problem with a soggy low end is not because your VE table is not right, but more likely because you're not running enough timing down low. My cam is around 233/235 @ .050" with a 112LSA. My motor has a very smooth idle with 32 degrees of timing. My Base Spark tables also match the 32 degrees at lower rpm. You may want to look at where your timing is on all 4 spark tables before you blame the VE tables. Also keep in mind that changing the spark will also change your VEs. Do the timing first, then re-do your VE tables. Worked for me.
__________________
Old Oct 9, 2005 | 04:05 PM
Just for shi_s and giggles...Go to the following link and see the photos I took of my stock VE table and my current modded VE table...
http://community.webshots.com/myphot...umID=472210893
It may appear fat to you guys, but as far as my L-trims are concerned...The stay between -2% and -8% at cruise and light throttle acceleration...Which, by the way, I have my throttle position set at 40% before PE is enabled...
Peace...Gman
Old Oct 9, 2005 | 04:07 PM
i have no problems with the f13 tuning it anywhere besides letting off the throttle it wants to pull a lot of fuel but ill find that out with the WB this week. i have my license now so i can check **** out. i am wondering if that dip has anything to do with cam overlap? im just glad im not the only one, i was kinda worried about it. the more i tune this cam the happier i am. car gets smoother and smoother and the little problems go away. last fill up i got 16.6 mpg, and that was a lot of idling and high rpms for logging. i was quite impressed heads and cam could do taht good in the city.
