Acceptable LTFT variance between banks?
Bank 1 was always slightly higher, but now on Decel, and idle (High Vacuum Moments), Bank1 is about 7% leaner. During Acceleration they are about dead even, so I figured a vacuum leak is probably to blame. I recently insaled 60 lb injectors with the turbo install, and it looked like some where not seated as deeply as other in the stock LS6 manifold. I even heard a vacuum leak coming from one of the injectors O rings in Bank 1. The solution for me was to bend the fuel rail mounting points, and now they all sit in deep, and no more leaks (99% sure of that!) I thought for sure that was why Bank 1 was running leaner.
BUT bank 1 is still running leaner. I even switched the O2s from left to right, same thing. I'm thinking about switching the injectors from one bank to the other, but since the LTFT variance only really occurs at idle, and decel, and steady slow to moderate speed (high vacuum), I still think it is a vacuum leak.
Any ideas, and is 7% even anything to worry about?
Thanks for any info.
Tommy
Tommy
Dixit
Tommy
If I wanted to get them flow tested, I just send them out via the mail? What is the turn around time?
Thank for all the info.
Tommy
Also was your Injector vs MAP table tuned correctly?
Dixit
Just as an aside, lets say I get the injectors flow tested, and if a few injectors are clearly not within the same limits, what is the next course of action? Replace just those few injectors? Of can they be tweaked to flow the same?
Thanks again for all the info.
Tommy
PS A twin turboed Z06 is absolutely halarious to drive!
