A/F on Dynojet vs the track, difference in load?
My ideal is go have 13:1 at the track.
I myself am shooting for a 12.1 on the dyno which I am told by numerous people will be about 12.5 on the street. Supposed to be just right for FI.
Glad he's tuning and buildin my LS6 Setup <img src="gr_grin.gif" border="0">
JS
also factoring in is wind resistance.. which puts more and more load on the car the faster it goes.
I'm sure he will lend an ear...
Wasnt trying to sound Cocky.
But u sure took it that way...
I gotta rember PSJ = SENSITIVE <img src="gr_grin.gif" border="0">
Just kiddin John
Joel
Well JULIO at CARTEK seems to know EXACTLY where to target your A/F in relation to DYNO and TRACK...
<hr></blockquote>
Sure he does. That must be why the only Cartek cars that run good are the ones that they race themselves.
Anyway shoot for 12.7-12.8:1 on the dyno, which should get you near 13.0 at the track, but remember every combo is different. Don't be afraid to play with the tuning at the track.
Any more opinions?
<strong>First of all, never question onfire... hehe, hoohoo, haha... Food for thought... How many seconds does it take you to accelerate from 50 mph to 130 mph on a 4th gear (3rd auto)dynojet run vs 50-130 on the street... Quite a bit different!</strong><hr></blockquote>
That is a very good point, I would then expect to be more lean on the street since there is much more load. More work for the injectors too.
<strong>John, email Dave Inall...about a year ago we traded emails on dynojet a/f vs track load a/f when I was thinking about buying a wideband o2 sensor...Dave was very helpful and has done dynojet vs track vs engine dyno a/f tests</strong><hr></blockquote>
You mentioned Dave Inall, for the rest of the people that don't know, he is the Incon Turbo guy. You have to approach a forced induction car totally different than an N/A car. A forced induction car that uses an FMU will go all over the place on a dyno. I have seen combinations go 13.3:1 on a dyno, then drive immediately to the track and run so rich that they popped and sputtered all the way down the track. $400 wasted on a day's worth of dyno tune only to go slower. Boosted combinations are very much load sensitive and the fuel curve is usually very sensitive as well when an FMU is used. That's just one of the many reasons I don't care for an FMU. Match the injector to the targeted power level and run it 1:1. <img src="gr_grin.gif" border="0"> But that's just me.
A dyno is just a way of getting a ballpark figure of how everything is working together. On a car that is N/A, it doesn't matter a ton if the car is 12.8:1 or 13.1:1 on the dyno. Keep in mind, your fuel/air will more than likely not be a constant while you're making a pass down the 1320 unless you are using an aftermarket fuel management system with wideband correction capabilities such as the Speed Pro SEFI8LO for examble. Tuning a car is all about looking at every variable and knowing where to pull fuel, add fuel and adjust timing tables. If you're tuning a car to drag race, the tuning should be done at the track. Dynos are nice for comparison's sake but they are not a concrete way of making a car run the numbers. Also, be weary of anyone telling you to make a car run X fuel/air ratio. No two cars are exactly the same, they will all like something a little different. Keep in mind that not all wide bands are created equal, what reads 13.1 on one is not always the same on another. Electronic gadgets are great but what matters is how long it takes to get from the starting line to the finish line. The bottom line is, keep an open mind and don't be afraid to try new things.
<img src="gr_tounge.gif" border="0">
My car (stock) runs leaner the faster it goes.
First gear gets the same AutoTap 02's, but by the time I go through the lights, it's about 0.05 leaner than the dyno.
But as has been pointed out, even NA cars will vary their a/f ratio. From what I understand the inertial load of the dyno is equivalent to a 2800lb vehicle. As you put more load on the engine your a/f ratio's will lean out. This is why McRat sees leaner conditions at higher velocities; he is in a different gear, and so has a greater load on the engine.
The dyno is a tuning aid, but it should be kept convservative; the agressive changes should only be made at the track/in operating conditions.
Chris
What about the COUNTLESS 11.7 or better C5 H/C cars that roll outta Cartek?Or is that a miirage too.
Oh thats right it RELLY was YOUR MMS STAGE 9000 400RWHP Monster that could only muster a 12.2? BWAHHHH BWAHHH BWAHHH
Terry its time for your meds
Mental illness must be tuff
I waiting to hear how much money u make a yr and how great u r and how many F-bodies u had and how u blah blah blah....
JS
Lets just wait and see what I run Terry
[quote]
<hr></blockquote>
Actually it ran 11.3 (note: quicker than your car)… but on motor it ran 12.2 with a 2.0 60' time, and it was a "stage 1" setup. Heads cam only cost $1500 brand new (no lip service discount like Cartek is giving you). I was happy with the setup, I spanked Z06's left and right at my local tracks. <img src="gr_images/icons/wink.gif" border="0">
[quote]
<hr></blockquote>
You're the one that keeps bringing that up.
<strong>Cartek is ok, they are no better or worse than any of the other new comer fly by night LS1 performance shops (Thunder Racing, More performance, Jay Fisher Racing, etc) <hr></blockquote></strong>
terry, wtf are you talking about?? <img src="images/icons/confused.gif" border="0"> i have bought a ton of stuff from both more and thunder for MANY years now and have been more than pleased and will continue buying my parts from them. <img src="images/icons/rolleyes.gif" border="0">
[ December 21, 2001: Message edited by: wickedZ ]</p>
