How do I get rid of the Airbag light?
Old Mar 28, 2002 | 09:13 PM
Big Mike's Avatar
Default How do I get rid of the Airbag light?
I installed a new Billet Specialties Steering Wheel, and now I have the Airbag light on at all times. How do I get rid of it?
Old Mar 29, 2002 | 01:43 AM
ChrisB's Avatar
Default Re: How do I get rid of the Airbag light?
You can use a resistor of the appropriate value (I do not know this of the top of my head, and would highly suggest NOT probing your airbag with a DVM to find out <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> . Hopefully someone who knows will chime in.
The other option is to pull your dash apart and remove the bulb.
Chris
Old Mar 29, 2002 | 06:10 AM
GeorgeC's Avatar
It's either a 1ohm or 2ohm resistor, but I can't remember which. Go buy some 1ohm resistors. Try a 1ohm. If that doesn't work, put two 1ohm resistors in series for a total of 2ohms.
Come to think of it now, I believe I ended up with two 1ohm resistors in series.
A pack of 5 should be less than $1.00, BTW.
Old Mar 29, 2002 | 06:21 AM
Big Mike's Avatar
Thank you guys. I'm going to try this. How exactly do I hook up the resistor? I assume I hook it up to the part that runs to the pcm? Do I make a "U" out of the resistor and put one end into each side? Do I wrap it with electric tape?
TIA!
Old Mar 29, 2002 | 09:55 AM
Big Mike's Avatar
TTT <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
I wanna fix this damn thing this wekend.
Old Mar 29, 2002 | 11:21 PM
GeorgeC's Avatar
Yes, just bend the leads so they will fit, and put it in the connector that was plugged into the airbag. You're basically just plugging in a resistance instead of the airbag itself.
Old Mar 30, 2002 | 06:17 AM
Big Mike's Avatar
Thank you George, I'm gonna give it a go. I'll post back to let you know how it works out!
Old Apr 4, 2002 | 01:21 PM
Big Mike's Avatar
George:
I put 2 1 ohm resistors together and it didn't work. I couldn't find any 2 ohm so I bought 2.2 ohm resistors and they didn't work either. Any ideas?
Old Apr 4, 2002 | 01:59 PM
jpatrick's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Big Mike:
<strong>George:
I put 2 1 ohm resistors together and it didn't work. I couldn't find any 2 ohm so I bought 2.2 ohm resistors and they didn't work either. Any ideas?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have never done anything with the airbags, but I can tell you that you will most likely not see any difference between a 1 or 2 or 2.2 ohm resistor. A regular wire will probably do the same thing that any of these resistors do, which is shorting out the two pins together.
Old Apr 4, 2002 | 03:45 PM
GeorgeC's Avatar
No ideas really... If I get a chance I'll take a look at mine and find out exactly what I used. It's been awhile since I removed the airbags...
Out of curiosity, did you try the 1ohm resistor by itself?
Old Apr 4, 2002 | 03:56 PM
GeorgeC's Avatar
OK, here's what I have... 2 1ohm resistors soldered together in series (2ohms). Here are a couple of pictures of the passenger side (driver's side is the same, but not as easy to access).
<img src="http://home.attbi.com/~gcoffey1/resistors.jpg" alt="" />
<img src="http://home.attbi.com/~gcoffey1/resistors2.jpg" alt="" />
<small>[ April 04, 2002, 04:00 PM: Message edited by: GeorgeC ]</small>
Old Apr 4, 2002 | 04:26 PM
Big Mike's Avatar
No George, I haven't tried just one 1 ohm resistor. The resistor goes into the female part of the Airbag plug right? How far in did you insert the resistor?
Old Apr 4, 2002 | 05:49 PM
Chris99WS6PWTMET's Avatar
Big Mike, You put the resistors in "series" right? Just making sure, because if you put them in parallel then it becomes a .5 Ohm resistor.
Sorry, I have no helpful hints as I still have stock steering wheel.
Old Apr 4, 2002 | 10:06 PM
GeorgeC's Avatar
Well, I didn't go back in and check the driver side, so I don't remember if it looks exactly like the passenger side in the picture... As far as I remember, there is only one place it can go, though... The resistor is just taking the place of the missing airbag.
If I have a chance, I'll drop the access panel in my car tomorrow and look at what I have on that side to see if it will help.
Old Apr 18, 2002 | 11:30 PM
BlackhawkSS's Avatar
so is this the only way to disable the light?
George did u ever have time to check the driver side?
Jerry
