Difference between regular HPT & EIO?
Old Dec 19, 2005 | 04:51 PM
SilverWS6_2002's Avatar
Default Difference between regular HPT & EIO?
Ok, before I take some heat for not using the search, I tried & it wouldn't load up for me, so I just have a quick simple question. What's the difference between HP Tuners & HP Tuners Enchanced IO? Thanks in advance guys.
Old Dec 19, 2005 | 05:06 PM
SideStep's Avatar
The EIO (Enchanced I/O) interface is for a WideBand interface... or other accessory sensor you choose to hook into the HPTuner Scanner...
Old Dec 19, 2005 | 05:28 PM
AdamSS's Avatar
Hptuners = $500
E I/O = $150
Wideband sensor = $200
_____________________
Total = $850
WHY TUNING MUST BE SO EXPENSIVE !!!!!
Old Dec 19, 2005 | 05:35 PM
JMBLOWNWS6's Avatar
Magnus should be sending out the new E I/O interfaces soon. I paid for mine but he didnt have anymore in stock and the three pigtails. We bought the shop version of HP tuners and it is awesome If you have a wideband and like to data log this is what you want. Pretty much anything you can reference from 0-5v your good to go
Old Dec 19, 2005 | 05:51 PM
ninobrn99's Avatar
do you have to send your regular cable in to get the eio upgrade??
Old Dec 19, 2005 | 07:12 PM
horist's Avatar
^^^ yes, they send you a new cable then with a new cable ID
Old Dec 19, 2005 | 07:35 PM
Thanks guys. Is there such a giant difference in going with the wide band as opposed to tuning using the factory narrow band? I'm sure the WB is much more precise...but for a newbie tuner, is tuning off the stock O2 acceptable?
Old Dec 19, 2005 | 07:51 PM
slow's Avatar
regardless of what anybody says, you can't tune WOT with a factory narrowband.
If i was to post up data from my AFM1000 wideband and factory O2 voltages, you woudl see the factory voltage is not consistant at all.
Ryan
Old Dec 19, 2005 | 08:29 PM
ninobrn99's Avatar
get the wideband!
