how much timing at idle
superheat the cats, but didn't want to reach 'POOF' stage.
Hawk
In other words, what is the shape of the graph? Does it decline with an increase of RPM? How much timing are you guys running in the upper RPM?
Not my car but I a horrible sick feeling in my stomach.The AFR was 14.6 and we had 30 of timing at idle... We backed timing down to 24 and the glowing went away
We were increasing the idle timing to get rid of some of the gas smell...
On my C5 I have LGs with cats all the way back next to the cat-back. If I use the factory idle timing (17*) the cats don't get hot enough to convert. When I set the idle timing to 26* I start getting that slow drip drip out of the exhaust tips, like you do with normal exhaust systems converting correctly. Also this ended the smell I had at idle.
But, I still get gas smell, and even some smoke at idle. I've leaned out my VE at idle by about 60%, 80% and 90% at 400, 800, and 1200, but I'm still rich.
Should I bump the timing more?
as for the idle, what's the VE number in the cells you idle in? more like 30 or more like 55? any more info on your setup? (injectors setup especially)
A well tuned car shouldnt need band-aid fixes like 30* timing at idle.
