Oil gage going crazy.
Heres some more info that might be relavent. At idle my pressure reads about 35. But at regular driving its about 45. Then if I get on it about 3/4 throttle it goes up to about 65. Then when I turn the car off the oil gage stays on. Help me if you guys have any idea what all that means. Thx.
Also, I checked my oil and its right at the crosshairs for being full. So its actually almost a little low on oil. Could that have anything to do with it?
How hard is it to replace the sending unit?
<small>[ June 04, 2002, 01:34 PM: Message edited by: CAlley2001 ]</small>
You'll also need a oil pressure sending unit removal socket, 1-1- 1/16" deep socket. Advance or Autozone have them to rent or buy.
<small>[ June 04, 2002, 01:54 PM: Message edited by: NastyC5 ]</small>
-Rob-
<small>[ June 04, 2002, 02:41 PM: Message edited by: 02BlueFirehawk ]</small>
<strong>Thx for the input guys. I'm not even gonna mess with it and take it into the dealer and they'll diagnoss it. You'd think if it was a guage problem that it would be covered under warrenty. But who knows with those guys.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I used to have a friend that worked at a GM dealer.. There was a TSB (technical service bulletin) on the gauge cluster when experiencing certain problems... I know that one of the problems is that sometimes in colder climates the trip odo will reset itself upon startup.. Tell em it does that, and you'll get a new cluster <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> They wouldnt replace mine cause i was a month out of warranty, but i was 4 thousand miles before the 36k limit.. Hehe GM has very bad customer service practices...
I have an appointment to take it in to the dealer in 2 days. They said it sounded like a bad sender. I sure hope so, they said I'm not covered under warrenty since I did headers w/ no cats. I'm probalby not gonna try to dispute it since I've read several posts on here about that and most people have had little luck.
I jsut hope it isn't the pump since I might have caused some engine damage by letting it sit and run for a few mintues. But like I said, when I go to drive then it comes on. And never drops below 35.
Any thougths?
DaveH
