O2s Don't Lock At WOT
despite a 100% indicated TPS.
Check the PE enable settings (MAP, TPS), the
PE mode delay value and RPM threshold. I think
something is locking you out of PE.
easy way to check would setup a status bit or at least see your IPW's That being said, They have shut off Pe mode, If you look at your pe mode delay times and rpm, you will see.
PE Mode Enable Hot and Cold Tables - All cells 90% (stock setting)
Hot/Cold table Thresh - 284 (irrelevent since both tables are the same.)
PE Enable Map - 55Kpa (stock setting)
PE Mode Delay RPM - 2000 (stock setting was 5500) (HPTuners says this is ignored on car calibrations. Does anyone know FOR SURE if it is used on trucks?)
PE Mode Map Hyst - 6
COT - Off
EQ Ratio - All cells stock values.
PE Corr Step Size - 0.020
PE Corr Apply Rate - .05 sec/step
PR Corr Remove Rate - .05 sec/step
Max Alowable Enrichment - 1.400 mult
On the log in question, the truck was at 100% TPS for 10 seconds so I think any time delay should have meen met.
about a minute every time, just for giggles"?
Once that gets right, then you can see how crazy
low the timing tables are. And how pointless /
oversensitive the burst knock setup is.
