Got computer done, car wont start! WTF!!
Old Jun 22, 2002 | 04:39 PM
NastySSoo's Avatar
Default Got computer done, car wont start! WTF!!
After my H/C install I had Ed wright do my tuning. Dynoed car and car was running lean 14-1.
Sent computer back to Ed with copy of dyno graph, got it back yesterday, installed it, and it turns over but wont start!! Took it out and put it back in three times!! Still wont start!! Im so *&$%*& pissed I could scream! WTF!!
Old Jun 22, 2002 | 05:14 PM
LS1derfull's Avatar
Default Re: Got computer done, car wont start! WTF!!
Have you tried cracking throttle with your foot?If it starts you may just need to let idle air counts relearn, this could cause no start without adequate airflow.
Old Jun 22, 2002 | 05:31 PM
NastySSoo's Avatar
No I havent. It doesnt even try to start. When he sent it back the first time it bump started like always!!Im assuming there is a problem with the tuning. The car ran perfect when I took it out.
Old Jun 22, 2002 | 05:34 PM
NastySSoo's Avatar
If you really think that is a possibility, Ill put it back in and try it. I had it out to send back to Ed on Mon. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 22, 2002 | 07:29 PM
Dipstick's Avatar
You might try disconnecting the connector to the MAF. According to the FSM, that puts it into the Speed Density Mode.
Old Jun 22, 2002 | 07:37 PM
NastySSoo's Avatar
Im confused, why would I need to put it back in the speed density mode? Im not doubting it, I just dont understand. Last time Ed had it the car fired right up after I installed it ? What would be different this time? Thanx
Old Jun 23, 2002 | 07:38 AM
LS1derfull's Avatar
He may have changed idle settings, its easier to try what i said than send pcm back isnt it?See what happens first.
Old Jun 23, 2002 | 09:15 AM
NastySSoo's Avatar
Thanks guys, I tried both your ideas and no go. It doesnt even try to start. It must be in the tuning. He set my idle and all other parameters the first time. I sent it back to have him richen it up a bit. Ill have to call him mon. Thanks for your input!
