calibrating 42#ers on ls1 edit.
where do i go on edit?
car is heads/cam 8.75:1 compression.
*currently running fastchips stage 2 h/c tuning*
about .910 wot and 30* timing, no KR stock 28# injectors.
for now it just hangs around 60psi at all throttles.
so you used 5.51.. that the only thing i need to change? there are a bazillion do-dads on edit. (tried it out tonight)
ed also locked my pcm (found out tonight).. what are my options? can i just read my friends 98 6 speed and write that over eds program or do i HAVE to have it completely reflashed.
if i buy another computer will there be a vin conflict?
a spreadsheet in this post listed below can help you scale...
http://www.speeddemonmotorsports.com...ectorscale.xls
https://ls1tech.com/ubb/cgi-bin/ulti...=000329#000020
<small>[ July 06, 2002, 09:34 AM: Message edited by: DaveSchott ]</small>
i inputted values from godspeed already.. the one he listed for 42# svo's going from 6.45-7.06
i found that in a thread where he posted.. i reformatted my computer and dont have excel yet so i cant check the whole spreadsheet.
<small>[ July 06, 2002, 11:49 AM: Message edited by: MIGHTYMOUSE ]</small>
<strong>any info on where i can get the pcm reflashed the cheapest? of if its fact that i can just overwrite my locked computer?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">For LS1edit to write to the flash first it would have to be able to read the PCM to get the VIN number and if its locked then it would fail getting that VIN so you would not simply be able to overwrite.
Also each car has of course it's own VIN number so just flashing with someones elses it would have a different VIN number.
Also Ls1edit does not overwrite the whole flash, just what is needed in the tables.
You need to go to a dealer or someone who has Tech-II or GM's SPS reflash programmer and brute force flash.
If it was me I'd demand the vendor give you back your flash intact since he did not own it to start with to lock you out of your own car's PCM <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" />
<small>[ July 08, 2002, 07:03 PM: Message edited by: Team ZR-1 ]</small>
