AutoTap Remedy
Old Jul 11, 2002 | 01:02 PM
BigTex's Avatar
Default Re: AutoTap Remedy
Thanks Mike. I went back to the DOS version, but will give the v2 another go.
Old Jul 11, 2002 | 02:59 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Hehe I read the 98 instructions and used them on xp. Needless to say, it didn't work and kept reinstalling the bad files. I made a log with it messed up and didn't know until just now. I got a knock retard reading of 841*, and it said I was at 45% throttle for like 15 minutes straight. I'll go try the right instructions this time. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Jul 11, 2002 | 03:07 PM
atapsalesmgr's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DriveATransAm:
<strong>good to see you figure out the problem. i have only installed it and not tried on the car yet. i think it said i needed a password and registration though? <shrug>
soon enough ill be able to test it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Let me try to clear up this issue for you. V2 software will work with V1 hardware without the need of a registration key. And, V2 reads both generic and enhanced parameters regardless of hardware version.
Actually, when the software starts up, it checks to see what type of hardware it is connected to, V1 or V2. If it's V1, it bypasses the registration process. That said, we've had a couple of reports like yours where V1 hardware users are getting prompted for a registration code. YOU DON'T NEED ONE. Make sure that your startup process is
1. Key On,
2. Connect the cable to the vehicle,
3. Start the software
Another helpful hint that will make the startup process quicker is to save a config file before you close the software the first time. When you connect to the same vehicle the next time, the software loads the last config file which contains all of the eligible parameters for that car.
Lastly, the hardware upgrade is optional. The new software works with the V1 hardware. You will need to upgrade your hardware, however, if you want to use EFILive V5 Pro or AutoTap for Palm.
Hope this helps. It's right for the horse's mouth!
Old Jul 12, 2002 | 12:43 AM
AutoTap-Mike's Avatar
Default AutoTap Remedy
Guys – we’ve been working frantically to discover what’s been causing the issues that many of you have experienced with our V2 software download and we think we’ve gotten to the bottom of it.
With the AutoTap V2 install, we built in a mini “demo” database that had just a handful of parameters. This database is part of the default config and default log file included with the software. It appears that this database was corrupt. The impact of this is widespread. It causes each of the following behavior:
Bad data in your own log file playbacks and exports
Trouble saving your own config (which was built on top of our default config)
Overflow error when playing back a log file, since it was attempting to playback into the corrupted default config.
Windows 95, 98 and ME users follow these steps
1. Close AutoTap software
2. Use Windows Explorer to locate your AutoTap V2 program directory (Default is C:\Program Files\AutoTap Diagnostic Scantool)
3. Delete the following files
AutoTapV2.ATD AutoTap Definition File (only exists if you’ve already connected to a vehicle)
Default.ATC AutoTap Config File
Default.ATL AutoTap Log File
(Note that depending on how you have configured your Windows Explorer, these files might appear differently, be careful you don’t delete the Application file.)
4. Restart AutoTap software. After your first connection to a vehicle, save the config file. AutoTap always loads the last-used config file
Windows XP and 2000 users follow these steps
3. Download the files Default.ATC and Default.ATL
from http://www.autotap.com/WindowsV2Remedy.html
Note- if when you restart the AutoTap software, the Windows Installer comes up, it means that the new default files were not successfully copied into the AutoTap Diagnostic Scantool directory, retry the steps above.
-Mike
www.AutoTap.com
<small>[ July 11, 2002, 02:44 PM: Message edited by: AutoTap-Mike ]</small>
Old Jul 12, 2002 | 12:53 AM
DriveATransAm's Avatar
Old Jul 12, 2002 | 12:59 AM
horist's Avatar
Sweet! I'll try it today <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Hopefully no more 300 degrees of knock retard, hehe
Old Jul 12, 2002 | 01:00 PM
StevieZ's Avatar
How come I can only find parameters for Ltrims and O2s for Bank 1?? The parameters for bank 2 are not there????
Old Jul 12, 2002 | 02:05 PM
Team ZR-1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StevieZ:
<strong>How come I can only find parameters for Ltrims and O2s for Bank 1?? The parameters for bank 2 are not there????</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Do not feel bad, in just doing a short recording sitting at idle scanner claimed :
Time Stamp (seconds) Ignition Timing Advance(Deg) Calculated Engine Load(%) Manifold Absolute Pressure (MAP)(in Hg) Manifold Absolute Pressure (MAP)(kPA) Engine Speed(RPM) Vehicle Speed(MPH) Engine Coolant Temperature(°F)
57870.98 2052.5 31.4 48.4 164 3 29 7648
57871.53 -64 1671.4 23.6 80 41 8 43
57871.97 2056.5 0 1256.8 4256 20 102 -17
It would be neat if my engine could do 2,000 plus degrees while the engine water temp was ver 4,000 degrees while RPMs was 3, but highly doubt I could ever achieve that <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Very next PCM cycle timing is now -64 but engine load is over 1000 !
<small>[ July 12, 2002, 02:10 PM: Message edited by: Team ZR-1 ]</small>
Old Jul 12, 2002 | 02:34 PM
eboggs_jkvl's Avatar
Actually, the Windows software was recreating the missing files in W98 also so you probably didn't screw up.
The fix now per A-tap site for all windows versions is delete the files ( you can actually just overwrite the bad ones, same thing) and download the 2 files from the a-tap site. If you have connected to a car, then you need to delete 1 more file.
ITT
Old Jul 19, 2002 | 10:02 AM
Guys, things are progressing well to have a file available later today that'll patch the known issues in V2 of the AutoTap software. Check out our download page at the end of the day (7/19/02).
That said, I have made the old version (1.11) available for those of you that may have deleted it <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> when you installed V2. Hopefully it won't be necessary, but it is available if you need it. You can only get to it by going to this web address: http://www.autotap.com/files/download/v1.11/setup.exe. It will also be available on our ftp site - ftp.autotap.com.
Thanks for sticking with us. Have a great weekend.
Mark
