HYPERTECH POWER 3
Old Aug 10, 2002 | 02:26 AM
scqqby's Avatar
Default HYPERTECH POWER 3
When Power Programmer is installed it says to listen for pings (detonation) in you engine. What exactly does this sound like? I thought I was Hearing it so I programmed it back to stock, and still hear it. Did anyone else ever have this problem? My Mods have so far been a 160 degree therm. Borla exaust system, Max airflow sensor, KN airfilter, max flo air box, Y-pipe. I just put in the Max Airflo sensor, could that be a issue? What is the temperature reading on the dash with the power programmer installed and a 160 therm. My is staying at around 200 degrees, is this normal? Any help would be appreciated. <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Aug 10, 2002 | 10:19 AM
justin sutton's Avatar
Default Re: HYPERTECH POWER 3
I have an 02ss a4 lid,mafends,macs,offroady,fra,maft,hpp3,&160stat the car with the powertuning installed always pinged that is with my o2 millivolts showing 940to950 that is way rich & still getting 2.5 to 3.2 knock retard.I read this with a scanmaster.I bought it & a maft at the same time money well spent might i say.I took the power tuning off knock retard went away & got to set my o2s back down to around 880 or 890 runs way better as for the cooling issue my factory temp guage still reads around 210 DO NOT GO BY THE FACTORY GUAGE it is off my scanmaster shows 170 when i am showing 210 on the dash.You will know if your car is pinging it is very anoying hope this helps some.
Old Aug 10, 2002 | 03:19 PM
scqqby's Avatar
Well I think I am hearing it when Car is in first gear and going around 5 - 10 miles per hour. I thought you were only suppose to hear pinging when you accelerate hard. Then I don't hear it anymore in second gear.
Old Aug 10, 2002 | 03:22 PM
i would say get a scanmaster you can get them from about any of the sponsers ramchargers makes them thats the only real way to see.
Old Aug 10, 2002 | 11:15 PM
scqqby's Avatar
What did you use to adjust your o2s, a MAF Translator. Is so how hard is it to do.
Old Aug 11, 2002 | 09:40 PM
I used a maft it is very easy.
Old Aug 12, 2002 | 03:36 PM
AZ28driver's Avatar
If you are hearing it at 5 to 10 mph i doubt it is a ping that you are hearing. I have the hypertech program in my car with the 160 stat and get a slight ping between 5000 to 6000 rpms on hot days (air temp above 90). On days when it gets that hot i just take it easy on the car and short shift well before 5 grand.
Old Aug 12, 2002 | 03:44 PM
scqqby's Avatar
Thanks For all the help. For future trouble shooting i wen ahead and got the scanmaster and the maft. Because I plan on doing more mods. I am not sure that is was a ping either. I wentt ahead and took off the power tune and the mass air sensor and just about everything else i had modified on the car. The onlt thing that was left that i added that was left was the Borla exhaust and I sill heard the same noise. So whatever it is after taking off the mods and going back to factory it did not change. Thanks for the help. Adding y-pipe and mass airflow bellow kit this week. I should aslo have the scanmaster to see what issues i am having if any, again thanks for the help justin and dlatwood.
Old Aug 13, 2002 | 09:44 AM
Bill's Avatar
Another question:
I found that with powertuning "activated" all was well - no pinging of any kind with premium fuel.
With the HPP3 one may adjust the max engine RPMs from 5,500 to 6,600, with 6,000 being stock.
I put it to 6,200 and am happy . . . I hear no valve clatter or pinging. The heads, valve train, and cam are all stock.
Also set the Cooling Fan On/Off Temperatures - for a 160 thermo.
My question is at what max rpm may our LS1s be set at without the risk of valve clatter? It's my understanding that if that happens, the valve train deteriorates. What about 6,400? LoL <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 13, 2002 | 10:57 AM
NoGo's Avatar
It really depends on what the conditions of the tolerances are in your valvetrain. When my valvetrain was stock, I had valve clatter near the stock limiter 5500 - 6000. FYI my valvetrain crapped out at 32k.
Pushing the limits of the stock valvetrain is living on borrowed time IMO.
Old Aug 13, 2002 | 02:44 PM
Bill's Avatar
Thanks, NoGo! I appreciate the dangers of valve float, but figured, you only live once. Will put it back down to stock - 6,000 rpm. It sure felt healthy though and, "I hear nuttin". Perhaps, if I had a stethoscope. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
