Knock Sensor Level
How many of you guys have played around with knock sensor sensitivity reduction???
I believe on any N/A or forged internals tune, reducing the sensitivity is probably acceptable. Has anyone played with these settings, and if so, how did you go about determining what levels to use?
I just tuned an 04 Z06 with LG LT's and was only able to pick up a few HP with tuning (knock sensors are very sensitive with stock settings). Once I got a nice 13:1 AFR, timing tuning was a bitch....anything over 22* advance was retarded
I know these cars are good for 27-28* all day long, so I reduced the AFR to 12.5-12.6 and bumped up the advance to about 26-28 ramped from 2500rpm. At the same time, I adjusted the knock sensitivity down slightly to make knock sensing a bit LESS sensitive, but not much.
This made all the difference in the world and the car ran strong...final numbers were 16RWHP gain with ~12.5AFR and 27-28* max advance. After the headers and tuning the car picked up a whole 27RWHP
This is also with all the retard tables left STOCK.
Before tuning the car would not even chirp the nittos. After tuning, it spun like hell
Again, if anyone has played with these settings, please report your results.
I would definitely suggest NOT editing this value over 26 or 27, unless you are tuning a forged motor and just looking to squeeze out a couple extra degrees....Either way, always listen for pinging. This is only necessary to squeeze out that extra little bit of power at the compromise of safety. How much you scale the knock sensor level upward is how much you are compromising safety.
But again, only scaling it up maybe 10% while maintaining a safe AFR under 12.9, you should have nothing to worry about.
What was your power gain before and after using this method?
What was your max timing before desensitizing? Also, a lot of people think that maximizing the amount of advance is the goal... IT IS NOT. Sometimes a motor will be happier at a certain spot running 24-25* instead of 26-28. Usually these cars can take 28* and like it, but again, you have to make sure that the extra timing is necessary. If you are making 350hp at 26* and making 350hp at 28*, then obviously 28* is not necessary.
Also, I suggest to anyone that uses the above desensitizing method to be careful...do not try it unless you know what you are doing.
Again, if this is on a non-forged motor, you are MOST LIKELY going to be okay if it is an N/A car. If this is a power-adder car (Nitrous/FI) with stock internals, I would suggest avoiding this method altogether or only make very small adjustments.
I need to dig back into my tune...I still feel I am safe, and think the parts I am running were causing me problems.
It would be a good idea to have somewhat more of a grasp on this concept, but people swapping an LS1 to an LS2 have this type of issue since the knock sensors are in the side of the block, and need a different calibration.
If it blows, it blows, but I don't see that happening if it hasn't done it yet. I've actually gotten knock a couple places (high load, low RPM) even with these settings, so I know the sensors are still working.
I traded in my edit a couple yrs ago or whenever HPT came out. My opinion is that HPT is far more powerful than edit.
I would definitely suggest NOT editing this value over 26 or 27, But again, only scaling it up maybe 10% while maintaining a safe AFR under 12.9, you should have nothing to worry about.[/QUOTE]
where in HPT are u doing this??
Make sure you understand what you are doing before you mess with that stuff
their threshold knock detect level is? Anyone mapped out
no-knock, "silent knock", "can of marbles" levels? I'm
wondering just how much latitude there is, between
oversensitivity, tolerance and loss of protection.
I guess maybe you could dial it down on a conservatively
fueled/sparked car, find the "noise floor" and then offset it
up by some amount. But, what the difference between
baseline mechanical clatter and actual knock impulses is,
is the real question. Probably very variable I expect?
