SES light in Rain
PS. Also the car feels like it idles a little rough.
Unless you CLEAR the light it wont go out untill you have gone through 3 drive cycles(could take 100 plus miles) AFTER the problem has been rectified, Kens easy solution for your problem(cause most likely its a phantom code) disconnect the battery for 5 minutes, that should clear the light and reset on the onboard monitors. drive the car,IF the MIL comes back on there IS probably an underling problem.(PS what did you use to "clean the sensors? If it was brake parts cleaner,etc. yeah they are probably phucked now
) My shop sees alot of these when there has been a REALLY big downpour and alot of the time we clear the code/blow out the connections and the cars are good to go. Good Luck. Bill
Bill
, cleared the code, and drove the car in the same loop I did yesterday. Light did not come on.
I'm driving 350 miles to gainesville this weekend to see the g/f, so we'll see if it comes back.
