A4 ported MAF kills transmission? HELP!
Old Sep 15, 2002 | 04:25 PM
Damage Inc.'s Avatar
Sweet Cheeks
Default A4 ported MAF kills transmission? HELP!
I was reading that a ported MAF, Granatelli, lower trans line pressure and causes sloppy shifts and can produce more heat - resulting in transmission failure. Any word on this? HELP! Should I even bother buyng one. Forget it? Is it worth it? Can I fix this problem? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 15, 2002 | 05:11 PM
justin sutton's Avatar
Default Re: A4 ported MAF kills transmission? HELP!
I have ends on my car with a vig 3200.It does shift softer but most of that is the vig.Put a transgo in it it will cure your problems if you have them.
Old Sep 15, 2002 | 06:21 PM
WicketMike's Avatar
theres 3 things you can do
1. buy ls1edit and firm up the shifts and a bunch of other things.
2. install a shift kit
3. the easiest thing to do,, drop the tranny pan, and give the epc solenoid about 1/4 of a turn.
Old Sep 15, 2002 | 07:03 PM
I did the 1/4 turn on my tranny & it didnt help.I dont know if this has to do with the converter or what but it didnt do anything.
Old Sep 15, 2002 | 07:31 PM
Orange Krush's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dear John:
<strong>I was reading that a ported MAF, Granatelli, lower trans line pressure and causes sloppy shifts and can produce more heat - resulting in transmission failure. Any word on this? HELP! Should I even bother buyng one. Forget it? Is it worth it? Can I fix this problem? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well after 6,000 miles with ported maf ends I just lost 3rd and 4th in my car ! <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" />
It all started well, but turned awful in 8 short months ! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=000294
Old Sep 16, 2002 | 10:43 AM
F8L Z71's Avatar
12 Second Truck Club
Put a stock descreened MAF on it and call it good. Ported MAFs on 99+ cars cause nothing but trouble when the cars are modified. They also make tuning harder and do not create any significant HP. You can get the same amount of HP by using LS1 Edit or a MAFT to tune the air/fuel. They bigger sized MAF is not going to do anything for you unless you are running one of the big cube motors. The majority of fast cars that I have seen run the stock unit.
I had too many problems with a ported MAF on my car. For 8 months I could not figure out why the car woult not shift correctly and seemed so soft on the shifts. I swapped to a stock unit and IMEDIATELY felt the difference and the thing would shift like it was supposed to. So I am speaking from first hand experience, not just something I read somewhere. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 16, 2002 | 11:39 AM
CHRISPY's Avatar
Colonel gained NOTHING on his 422 from switching from a stock descreened MAF to a Gran 85mm MAF.
food for thought...
Chris
Old Jun 10, 2011 | 02:58 PM
needtransam's Avatar
anyone from this post still in ls1tech
Old Jun 10, 2011 | 04:35 PM
jimmyblue's Avatar
Moderator
Here's the word.
When you port the MAF you lie about airflow.
When you lie about airflow you lie about motor torque.
When you lie about motor torque you lie about line
pressure needed to hold said torque without slipping.
So say hello to your new bucket of friction silt, from
your 300HP disc sander.
Of course this is all fixable in the tune but ghetto mods
tend to be done with a corresponding level of clue and
funds. Personally I think this kind of thing accounts for
why some people go through transmissions like popcorn
with low mods, and some people get good service out of
one despite high power levels and racing weekly.
