HPP III Question
Old Oct 1, 2002 | 09:45 PM
LS1Formula98's Avatar
Default HPP III Question
I have recently installed 3.73 gears. I have an HPP 3 and am changing the gear ratio, When i do that though, it is asking me to put in the tire height. I have no clue what the height is. It gives me a range of anywhere from 24" to 30". The rear tires I have are Nitto Drags 275/40/17 . Anyone know what I am supposed to put here? TIA.
Old Oct 1, 2002 | 10:00 PM
Default Re: HPP III Question
Well, I am going with 25.75 Hopefully that will work.
Old Oct 1, 2002 | 10:52 PM
1999Daytona500PaceCar's Avatar
Uuuuuuhhhhhhhhmmmmmmmmm... Measure 'em! DOH! <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Seriously, just take a tape measure and measure from the pavement to the top of the tire - then that is what you enter into the HPP3. Good luck!
Old Oct 2, 2002 | 05:58 PM
Bill's Avatar
The HPP3 manual says:
Place a chalk mark on the tire where it contacts the pavement and also mark the pavement. These marks should be at the center of the tire footprint pointing straight down to the pavement.
Roll the vehicle in a straight line until the chalk mark makes one revolution and is pointing straight down at the pavement again. Mark the pavement again at this new spot.
Measure (in inches) the distance between the two (2) marks on the pavement. Divide the measurement by 3.14159. This will give you the tire height in inches.
I used masking tape and drew a line with a marker. My 275 g-Forces' d was 25.0" (C/pi = (78 11/16")/3.14159) & not 25.7" as per specs. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 4, 2002 | 10:58 AM
WJ SOM SS's Avatar
Another method: Stand tire on level floor. Place a 24" level across very top of tire. Measure from bottom of level to floor. The 275 Nittos should measure 25 3/4 to 26", depending how much air you're running.... WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 4, 2002 | 03:31 PM
AZ28driver's Avatar
Enter your tire info into this website is it will breakdown all the measurements for you. http://www.csgnetwork.com/tireinfo4calc.html
Old Oct 4, 2002 | 03:33 PM
AZ28driver's Avatar
Try this website http://www.csgnetwork.com/tireinfo4calc.html
Old Oct 5, 2002 | 08:22 AM
Bill's Avatar
Dlatwood, the U.S And Metric Tire Size Information Calculator that you listed is neat! For a 275/40 17" tire it gives a circumference of 80.62" and a diameter of 25.66".
However, my SLP option, BFGoodrich g-Force 275/40ZR 17" tires, by using HPP3's method detailed previously, gives a circumference of 78.69" and a diameter of 25.05"! I trust what I see and the HPP3 way is accurate . . . the speedo must continually reflect the actual distance travelled, divided by the time, if it is to be accurate . . . computers do a good job, but only if the numbers that they crunch are real. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
