Predator ?
Old Nov 15, 2002 | 09:59 PM
justin sutton's Avatar
Default Predator ?
How is everyone bumping the rev limiter up.Mine wont let me go up any.
Old Nov 16, 2002 | 06:15 PM
Default Re: Predator ?
I still cant figure out how to take the rev limiter up.I am still showing a not available when I try to raise my line pressure on my trans also. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Nov 16, 2002 | 08:37 PM
Anybody
Old Nov 16, 2002 | 08:39 PM
Anybody <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Nov 16, 2002 | 09:11 PM
TomQ's Avatar
did u try to call their tech support ?
Let us know how they were in help, i wanna hear how they support their products and customers
Old Nov 17, 2002 | 07:24 AM
landlord's Avatar
If you bought it from James bfblightningfourms.com his support is excellent all you have to do is call him. except for the two weeks from the time I bought it for it to arive at my house. any problem I have had he was just an email or a phone call away. not to mention previous best time was 13.11 now 12.87 well worth the money
Old Nov 17, 2002 | 07:26 AM
landlord's Avatar
sorry thats bfb@lightningfourms.com
Old Nov 17, 2002 | 11:43 AM
I bought it from rpmoutlet.$425.00 2 days to my house.I called PDQ which is Diablo talked to a guy named Alex.He told me that they haven't had any problems with the shift firmness part but he would be glad to look at it for me.He gave me a reference # to put on the box and said send it back we will get it took care of no problem. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I still need to figure out why I can't or how I can bump my dam revlimiter up past 6190 though.
Old Nov 17, 2002 | 11:41 PM
zeeya94's Avatar
go to set paramiters. Then rev limiter. When you get there you have tho hit enter on each table. Then bump it up. hope this helps.
South Carolina F&Y bodies
Old Nov 18, 2002 | 04:54 AM
Bad02WS6's Avatar
How much can you Raise/Lower timing?
Old Nov 18, 2002 | 08:08 AM
Bad02WS6's Avatar
I found out. It's -5% to +5%
Predator says it is 2 Degrees at 5%.
I wish it could be lowerd or raised more.
Old Nov 18, 2002 | 08:29 AM
zeeya94's Avatar
I guess these preditors are different. We raised it to 6400. And we could raise it higher. We didnt have the +/- scale for this option. you go up or down.
Old Nov 18, 2002 | 09:18 AM
It wouldnt let me go any higher than 6190 on the rev limiter.I am going to get them to fix that also when I send it back today.
Old Nov 18, 2002 | 11:59 AM
BullSSeye's Avatar
Just make sure you are in the "set performance" mode rather than the "view performance" mode. Once you're in there and you have selected the redline scale, you should be able to adjust it. If you still can't then that part may be defective. But it sounds like DS is going to check it out and fix the problem promptly. I have heard their customer service is top notch. So this is a good test. Let us know if evreything is resolved satisfactorily. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Nov 18, 2002 | 01:51 PM
I did have it on set perimeters.It would let me set other things but not the shift firmness or the rev limiter would only go to 6190 which it was already set at.I sent it next day to diablo beause I need it this weekend bad.We will see how fast they are.I will keep everyone posted.
Old Nov 18, 2002 | 02:19 PM
Rob SS's Avatar
I had a problem with the tunng incompatible with my car (99 SS). I sent it back to Diablo UPS next day and it was return quickly also UPS Next day. Also James at runningwiththedevil provides excellent customer services.
Old Nov 21, 2002 | 04:49 PM
jacs's Avatar
Was you going to performance shift or normal shift, our cars don't have the performance shift, tow.
as for rev-limiter it just let me select the number i wanted got mine at 6200,
Old Nov 21, 2002 | 08:08 PM
I got my diablo back today.They sent a new one.The other one was toasted for some reason.
