Any LS1 EDIT Tuners In NORTHEAST OHIO
Thinking of changing from Ed Wright programming to LS1 Edit but I would like some one to do the inital tune for me to be sure I dont blow anything up. Any shops in NE Ohio that tune using LS1 Edit?
Thanks
Thanks
Were just under 2 hours from buffalo! if your interested give us a call!! 866-539-4605 <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Barry
I e-mailed you guys a while ago and still have not got a response. It was in regards to your walbro fuel system for the f body. I have a 01 and was wondering if your kit will work with my 01 or what mods need to be done to make it work.
Also was wondering if I could put a 100 shot of N20 on my motor.
I have a ARE 346 short with ross boost pistons and ARP rod bolts, ARE stage 2 heads, with a custom grind cam. It makes around 420 at the wheels now.
I know you cant warrant my motor under N20 conditions but will it handle a 100 shot?
How far are you from Cleveland Ohio?
Thanks Rob
Thanks Rob
Doc
I have a ARE 346 short with stage 2 heads, custom grind cam, ls6 MAF, 12 Bolt with 3.90's, 165 stat, Lid, KN, Longtubes no cats, Borla catback, Air pump and rear O2's deleted, Skip shift deleted. 900 rpm idle,
Im sure I'm missing something. All bolt on with heads and cam
I'm looking at adding 100 shot and 30 lb injectors.
Any ideas? Getting expensive to keep sending it off to Ed.
I'm gonna buy LS1 edit but I would like some who knows it to do the initial tune.
Rob
<small>[ December 23, 2002, 12:49 PM: Message edited by: LEATHL_WS6 ]</small>
Rob
LS1TECH Sponsor
You guys should make the trip North to ARE. They do first class work there. We do it here to but we are 8-10 hours away! Give Wade a call 905-420-9195.
Hey Mike how are you?
Its Rob with the White WS6. I've been think about coming to see you and have you tune it for me. But like you said its a 8 hour trip.
Cars been running good after I had Ed adjust the tuning I went 11.74 at 117mph.
What would it run me to bring it up and have you tune it. I'm going to buy my own copy of LS1 Edit so I have it.
Have a happy Holidays
Rob
Rob
LS1TECH Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LEATHL_WS6:
<strong> ttt </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Give me a call Rob. I'll make you a deal you can't refuse <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Mike
Mike
There is a guy opn the east side of cleveland the shop is called dynotech.I've heard he is good but mostly he does mustangs. He claims that he can do a LS1 Edit tune but you would have to buy the software.
I will probably be taking mine to Rapid in PA. Mickey is a great guy who really knows what he's talking about. He stands behind his work 150% you wont meet a better guy to do business with. It's a drive but well worth it.
Lethal,
I sent you Email, in addition,
Do you think that the same tune would work when spraying NO2, as well as, NA???? Tuning could be done on a chassis dyno while spraying NO2. When not spraying, you would be a little rich but not bad, but this would depend on the NO2 kit that you install. One of the NO2 companies advertise that the stock fuel system is adequent.
Installing 30#/hr injectors is OK, but at what pressure is the injectors rated at???? If you do install 30#/hr injectors, the fuel table should be updated for the increased flow rate. This I know can be done with LS1Edit.
FWIW: My '99 SS is a heads/cam car and I am still using the stock fuel system, however, my duty cycle is 100% at WOT because the PW is 20msec at 6,000rpm. The stock injectors flow 26.5#/hr.
