where can i change crank output on pcm to 4 cyl? HP TUNERS
where can i change crank output on pcm for 99 firebird ls1? I have an autoemter tach setup for 4 cyl. Id rather not have to take dash apart and cut the wire to convert it.
Thanks
Dave
Thanks
Dave
you don't need to change the PCM... if your Autometer tach is setup for a 4 cylinder then just tap the tach wire and you're set...
w/the way our crank signal works you have to make items that feed off the tach signal think it's a 4 banger signal (just like if you install an MSD window switch, you have to cut both wires so the window switch thinks the input is a 4 banger)
i know that but i was told that there was a place in HPT to change to 4 cyl crank signal pulse w/o affecting anything else. Id hate to have to tear my entire dash down just for this.
Dave
Dave
