P0101? What do I do? ***UPDATE : PROBLEM SOLVED***
Old Jan 27, 2003 | 10:34 AM
LOnSLO's Avatar
Default P0101? What do I do? ***UPDATE : PROBLEM SOLVED***
Started throwing this code about a week ago. The car is stumbling in the midrange, but runs good at WOT. All I can find out about this code is MAF performance. It's a home ported job, but has been working great up until lately. Installed a new cam about 2 weeks ago, and that is when the probs started. Ran fine for months before. Are the sensor wires fouled in any way? Need some help from the PCM gurus. Thanks in advance. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ January 30, 2003, 06:18 PM: Message edited by: LOnSLO ]</small>
Old Jan 27, 2003 | 06:57 PM
LOnSLO's Avatar
Default Re: P0101? What do I do? ***UPDATE : PROBLEM SOLVED***
Anyone <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 27, 2003 | 09:16 PM
ss rally red's Avatar
Hey Ryan, I am no expert but I will check AllData tomorrow morning to see if I can find any help for ya.You are also welcome to come down and use any of the info and scan equipment we have available free of charge anytime if you want. My tech has a great real time set up from snap on,that may be alot of help. Anything to help out a fellow f-body brother.Ken <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 27, 2003 | 09:27 PM
LOnSLO's Avatar
Damn thanks Ken. Where is your shop? I'll be down there in no time. Appreciate it!!!!!!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 27, 2003 | 09:28 PM
Classic's Avatar
Ryan, I think the problem is that your car expects to run 11s, but since you can't quite get there it has decided to be bitchy <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Just throw a stock maf in there and see what happens. If you need to borrow mine for the weekend you are welcome to it.
Old Jan 27, 2003 | 09:34 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LOnSLO:
<strong> Damn thanks Ken. Where is your shop? I'll be down there in no time. Appreciate it!!!!!!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey Ryan We are in Snellville, call me at 770-978-8502 and I'll give you directions. I am looking to follow your mods as soon as I can afford them. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 28, 2003 | 06:55 AM
Hey Ryan I printed the info off of AllData,makes for some interesting reading. Give me a call at the number above and if you have a fax machine available I'll send it to you. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Jan 29, 2003 | 10:38 PM
Jake99SS's Avatar
I've gotten this code twice in the past week. The car barely idles and can hardly start if it's been running. I've got a stock, unported, descreened MAF. Also heads & a T1 cam. The car ran fine up until the Sunday before last. I've got a friend that has stock MAF laying around so I'll try that, swap the plugs and see what happens. Anyone know if the P0101 code is a sign of the MAF going bad or can it be a symptom of other issues like a vacuum leak?
Old Jan 30, 2003 | 12:28 AM
JonCR96Z's Avatar
The problem is that your MAF readings are different from the PCMs caclulated readings due to the porting. Freind of mine has the same problem. You should stick a stock one back on or try to calibrate your ported one with LS1 edit.
Jon
Old Jan 30, 2003 | 12:40 AM
LOnSLO's Avatar
Yep, I have come to the conclusion that the MAF needs to be replaced. Now I'm just trying to figure why it started all of the sudden. I've been running the home ported MAF for months.
Old Jan 30, 2003 | 06:17 PM
LOnSLO's Avatar
OK, problem solved. There must have been some kind of residue on the sensor wires. Used a little rubbing alcohol and a Qtip, and guess what. NO MORE CODE!!!!!!! Damn car runs better than ever! No more surging on hot starts, and runs smooth as glass. YOU GUYS ROCK!!!!!!!!!!
Old Jan 30, 2003 | 08:22 PM
<strong> OK, problem solved. There must have been some kind of residue on the sensor wires. Used a little rubbing alcohol and a Qtip, and guess what. NO MORE CODE!!!!!!! Damn car runs better than ever! No more surging on hot starts, and runs smooth as glass. YOU GUYS ROCK!!!!!!!!!! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey Ryan, wasn't that one of the first thing's on the list that the print out from AllData suggested? I have a little over 15K on my SS now so I think it might be time to clean. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 30, 2003 | 09:11 PM
LOnSLO's Avatar
Yep. Thanks again Ken. I'll be keeping that printout for future reference. I owe you one <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
