predator dyno #
Old Feb 7, 2003 | 08:46 PM
jimmyblue's Avatar
Moderator
Default Re: predator dyno #
I'm really digging the transmission stuff
too. Not like new - better than new. It's
what I would have wanted out of a shift kit,
only it's just twiddlin' two e-*****. My
question to GM is, "Why didn't you set it
like this in the first place, dumb ***?"
<small>[ February 07, 2003, 08:48 PM: Message edited by: jimmyblue ]</small>
Old Feb 8, 2003 | 12:20 AM
koolrayz's Avatar
Default predator dyno #
I went to the local dyno did a baseline. then installed the canned tune then advanced the timing all the way out then leaned out the fuel all the way. ended up with 13.2 on the a/f on the wideband. later logging with the predator show WOT timing advancing 41 degree's. no KR. Only saw a 9 hp and 11 tq on a mustang dyno but it really flattend the curve out and raised the hp and tq rpm. car pulls longer and harder <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> . now the good stuff <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> the transmission changes make it drive like a new car. With the tq higher at the top end i raised shift points to 6200. reduced the shift time (-15) and raised the line pressure (+15) <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> The real time data is awesome. <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> So far im very happy with my predator. sure its not edit and atap. but it doesnt cost like it. and for my situation it worked out well.
2002 trans am only 2000 miles A4 2.73. mti lid, k&n filter, magnaflow catback <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> and now the predator <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
A BIG THANKS to jon at SPEED inc <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" /> <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
Old Feb 8, 2003 | 01:55 PM
roadrunner-r's Avatar
How much did you put down total hp?
Old Feb 10, 2003 | 03:10 PM
BullSSeye's Avatar
Just curious, did you try adding back to the fuel enrichment? The best numbers I've seen have come from 2 degrees advance and about 3.5% lean. Depending on your car/mods you may not want to take it that far out. Your gain is pretty decent, but there may be more in it. <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Feb 10, 2003 | 03:19 PM
ChrisB's Avatar
You are running 41 degrees of timing advance?!? Are you sure?
Chris
Old Feb 10, 2003 | 05:46 PM
WJ SOM SS's Avatar
31 degrees would seem more like it at WOT, no? WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 10, 2003 | 11:04 PM
koolrayz's Avatar
I am going to add some fuel enrichment back. it didnt make any difference on the dyno when went from 3% to 5%. i checked the timing again today and it really shows it advancing over 41 degree's at WOT the inlet air temp was in the low thirties. im not showing any kr.
Old Feb 10, 2003 | 11:24 PM
LS1 PLUS's Avatar
I thought only in 99 and very early 2000 GM used 2.73 gearing not in the final year of the f-body <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> are they ever going to learn??? i am referring to koolrayz sig
Old Feb 10, 2003 | 11:39 PM
koolrayz's Avatar
I wish that was true <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> But the reality of it is i got stuck with the 2.73. I bought the car the end of october and there were not alot of choices <img border="0" title="" alt="[Frown]" src="gr_sad.gif" /> . On the freeway at at 2000 rpm im going 80mph
