3.73 Gears/Predator
PS-Should I set the fans to turn on sooner due to the 3.73 gearing working the engine a little more?
I had to call my buddy at Diablosport (know the local guys that developed it) and I had to use tire size 235/40/14 as 'actual' instead of my old 275/40/17 under 'factory'
Enjoy the new gears, mine rock! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
<small>[ February 08, 2003, 07:23 AM: Message edited by: racer88 ]</small>
do it myself. Saw somw stuff going around
about how sometimes this didn't work right
and you had to screw with tire sizes as a
back door fix. I think they talk about this
on their web site.
I would set the fans where you want the temp
to be, then regardless of how hard it works,
the temp is the best indicator of that, the
fans will just do their thing.
You can call Diablosport in Boca Raton, FL and they will assist you.
Problem: Currently in all versions (v1.00, v1.01, v1.02, v1.03) the axle ratio settings will not adjust the parameters w/in the pcm that controls the speedometer calibration. This only applies to F-bodies that have swapped their rear gear ratio out from factory to a lower gear ratio.
Temporary Fix: Please, from the main Predator screen, select Tune It, Modify Parameters, and then choose Factory Tire Size and Actual Tire Size, and make the necessary adjustments as noted below:
F = Factory Tire Size
A = Actual Tire Size
2.73 to 3.23 - F: 275/40-17 A: 245/35-15
2.73 to 3.42 - F: 275/40-17 A: 275/30-14
2.73 to 3.73 - F: 275/40-17 A: 175/35-14
2.73 to 4.10 - F: 275/40-17 A: 175/30-13
3.23 to 3.42 - F: 275/40-17 A: 235/50-15
3.23 to 3.73 - F: 275/40-17 A: 205/45-15
3.23 to 4.10 - F: 275/40-17 A: 165/40-15
3.42 to 3.73 - F: 275/40-17 A: 235/30-17
3.42 to 4.10 - F: 275/40-17 A: 235/40-14
Future Solution: The issue has been addressed and the newest update, v1.04 will incorporate the fix. There is no specific timeframe as to when v1.04 will be released, but as soon as it is we will update the site accordingly.
