Low-Coolant light.......
I checked the radiator and it is full. Might I have a bad sensor? Where is the low-coolant sensor?
Any help is appreciated.
Thanks for the tip.
Started the car and the light was on. Unplugged the sensor and the light stayed on.
Later that day, the light was off. With the car running, I unplugged the sensor and the light stayed off <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> . At this time a friend drove up and we talked for a few minutes while the car idled. When I got in, the light had come back on <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> .
Drove 20 mins, and the light stayed on. Went shopping for a little while. Got in car to drive home, and light was off! Stayed off for the 20 min drive home. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Guess I need to invest in a multi-meter and learn how to use it. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
<small>[ March 06, 2003, 09:18 AM: Message edited by: 1CAMWNDR ]</small>
It sounds like that signal was basicaly "floating" or just picking up random voltages out of the air once you unplugged it. Try installing some kind of jumper in the end of the connector to provide a stable "simulated" signal to the PCM. The light should either stay on or stay off. If it still randomly changes, the problem is elsewhere. If it stays on, take out the jumper and start experimenting with different values of resistors. If it stays off, leave the jumper in permanently. BTW, multimeters are cheap and easy to use. It you need any help with that, ask away, I have 30 years experiance using them.
<small>[ March 06, 2003, 10:23 AM: Message edited by: Cal ]</small>
