Autotap and checking OBD readiness monitors / tests.
Old Mar 8, 2003 | 08:20 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Autotap and checking OBD readiness monitors / tests.
Is Atap able to check the status of all the readiness monitors for an OBD2 car? If so, how? I’m sure it’s possible somehow, but I’ve never actually tried before and there is no “I/M” button anywhere on the screen to click on, so what’s the secrete?
TIA <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 9, 2003 | 06:04 AM
EFILive's Avatar
Restricted User
Default Re: Autotap and checking OBD readiness monitors / tests.
The following 11 tests are defined for OBDII but not all vehicles support all of them - so you may only find a subset presented by any OBDII compliant scan tool.
Display all of the following parameters that appear for the connected vehicle:
Comprehensive Component Monitoring
Fuel System Monitoring
Misfire Monitoring
EGR System
Oxygen sensor Heater
Oxygen Sensor
A/C System Refrigerant
Secondary Air System
Evaporative Purge System
Heated Catalyst
Catalyst
Regards
Paul
Old Mar 9, 2003 | 10:16 AM
wrencher's Avatar
wrencher
For a vehicle to be OBD-II complaint it must display all this information in a generic/standardized format. The only tool I 've seen to get readiness tests , is a scan tool that has OBD-II generic capabilities> i.e. hooks up to any OBD-II vehicle.
Old Mar 9, 2003 | 11:05 AM
RPM WS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by wrencher:
<strong> For a vehicle to be OBD-II complaint it must display all this information in a generic/standardized format. The only tool I 've seen to get readiness tests , is a scan tool that has OBD-II generic capabilities> i.e. hooks up to any OBD-II vehicle. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> So you're saying a-tap won't give me the state of the tests? Somehow that doesn't seem right, I would think it would support readiness tests just as it supports DTCs and MIL command <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
EFIliveV5...thanks for that info, I guess I'll just have to look for these settings next time I hook up atap.
Can anyone confirm or deny that atap can give the correct state of each readiness test?
Old Mar 9, 2003 | 11:42 AM
66ImpalaLT1's Avatar
I have been told that Autotap does not read these test results.
EFILive5 does.
Eric
Old Mar 9, 2003 | 02:06 PM
Cal's Avatar
Cal
Sounds like to me he's telling you that you need EFILive5.
Old Mar 9, 2003 | 02:51 PM
EFILive's Avatar
Restricted User
I believe, if you have the AutoTap enhanced then (by default) you also have the generic. The generic is a subset of the advanced.
Anyway, if you have AutoTap you can always download and use EFILiveV5 (free). The *only* restriction is 5 seconds of data logging.
Without purchasing a license for EFILiveV5 you may still use EFILiveV5 to display:
- System readiness test results.
- Non-continuously monitored test results.
- O2 sensor test results.
- Immature, Pending, Current/MIL, History and Old DTCs for ALL modules.
- History data for ALL DTCs that store history info.
- Clear DTCs for all modules.
- Search for and display ALL modules.
- Search for and display all valid enhanced PIDs.
Regards
Paul
<small>[ March 09, 2003, 02:53 PM: Message edited by: EFIliveV5 ]</small>
Old Mar 9, 2003 | 03:52 PM
RPM WS6's Avatar
I found this information about autotap generic parameters:
OBD2 Parameters covered by Autotap Generic Software
A/C System Refrigerant Monitoring Status
Auxiliary Input Status
Catalyst Monitoring Status
Comprehensive Component Monitoring Status
ECT
EGR System Monitoring Status
Engine Load
Engine Load
Engine Speed
EVAP Vent Solenoid Command
Evaporative System Monitoring Status
Fuel Pressure
Fuel System Monitoring Status
Fuel System Status Bank 1
Heated Catalyst Monitoring Status
IAT
Ignition Timing
LTFT B1
LTFT B2
MAF
MAP
Misfire Monitoring Status
O2 Sensor - B1S1
O2 Sensor - B1S1 (mV)
O2 Sensor - B1S2
O2 Sensor - B1S2 (mV)
O2 Sensor - B1S3
O2 Sensor - B1S4
O2 Sensor - B2S1
O2 Sensor - B2S2
O2 Sensor - B2S3
O2 Sensor - B2S4
OBD Requirements
Oxygen Sensor Heater Monitoring Status
Oxygen Sensor Monitoring Status
Secondary Air System Monitoring Status
STFT B1
STFT B2
Throttle Position
Vehicle Speed
In that list are the 11 tests that EFIlive listed in his first relpy. So it looks as though A-tap will cover them. Not sure though considering I have a pretty old version of a-tap. I guess I'll just have to try and see.
Old Mar 9, 2003 | 05:01 PM
RPM WS6's Avatar
Ok, it looks as though a-tap will display *some* of the tests. I'm not sure what it would display for an LS1 car because I can't plug into my T/A till I charge the battery. I saw 8 of the tests on my '96 Bonneville that I just plugged into though.
So can anyone tell me if a-tap is showing all the tests that apply to that car, or do I perhaps need an update/upgrade to get all the tests shown above?
I don't think the free 5 seconds of EFIlive will help me, because my laptop is not internet capabile and my PC is too far from the car.
Thanks for the help so far guys <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 9, 2003 | 09:07 PM
wrencher's Avatar
wrencher
This is of the top of my head but 00' model year LS1= diagnostic readiness tests are,catalyist monitior,evap system,egr system,fuel trim ,missfire monitiors, o2 monitior,o2 heaters,& air pump system.
Old Mar 9, 2003 | 09:11 PM
RPM WS6's Avatar
<strong> This is of the top of my head but 00' model year LS1= diagnostic readiness tests are,catalyist monitior,evap system,egr system,fuel trim ,missfire monitiors, o2 monitior,o2 heaters,& air pump system. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">wrencher, thank you for this information <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I will a-tap my TA and check these out as soon as I get the battery ready <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 10, 2003 | 12:00 AM
RPM WS6's Avatar
I guess I need the autotap generic software then? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 16, 2003 | 03:52 PM
RPM WS6's Avatar
Just a quick update here.
I a-tapped my '00 T/A yesterday and found that in fact a-tap DOES show OBD readiness tests. There were 9 of them, all those that wrencher listed and 1 more.
They were under the diaonostic section, I have a-tap Windows version 1.10
Just an FYI to all who thought a-tap might not show these tests.
Old Mar 16, 2003 | 04:28 PM
Team ZR-1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RPM WS6:
<strong> Just a quick update here.
Just an FYI to all who thought a-tap might not show these tests. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">FYI,
There is eleven I/M 240 tests not 9.
Not sure your intent in doing I/M 240 but if its to assure your meeting the smog tests your not assured of results using a non certified scanner, both autotp and Efilive are not.
The only laptop scanner that I use that is EPA certified is the Ease GM scanner for it is also used by some states to do offical I/M 240 smog tests.
Also as per EPA the scanner must have one Icon that is clicked and reports the state of all 11 tests and also to put the results in a printable report.
Old Mar 16, 2003 | 05:04 PM
RPM WS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Team ZR-1:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RPM WS6:
Also as per EPA the scanner must have one Icon that is clicked and reports the state of all 11 tests and also to put the results in a printable report. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I disagree. Before turing tests back on with edit last year, I remember my EGR test showing incomplete. Now, it is complete. Why would it show the test but the info be incorrect? That makes no sense. EPA certified or not, the info is there.
What would the other two tests be? Everything was there per my helms manual. I only found 9 tests.
Old Mar 16, 2003 | 07:58 PM
wrencher's Avatar
wrencher
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The PCM passes it's own readiness tests not the scan tool that is used. That is a stipulation of OBD-II that it has generic scan capabilties . As long as the scanner can read it , it's just extracting the same readiness tests status's that any-other tool would. No matter what make '96 & up. I know cali. is alot diff. but most other states farm out emission testing to sub-contractors & they handle testing. Most of their systems are not "inpector" hands on systems. They just hook up to test port & their customized automated system checks it.> one tool to check emissions systems across the board.
