Timing Tables
Old Feb 25, 2006 | 01:51 AM
minytrker's Avatar
Default Timing Tables
I need to pull about 2 deg of timing out at wot from 4000-4800rpm. In Spark high octane table (B5913) it is showing 24 deg but in my data log Im am showing 29 deg. What table is increasing my timing from 24 to 29? Here is my data log from being on the dyno, I also have my tune online if someone wants to look at it. I am going bacl to the dyno tomorrow to try to get this fixed.
DYNO LOG
Old Feb 25, 2006 | 02:41 AM
white2001s10's Avatar
You may be looking too far down the table.
WOT is not always at the bottom of the table.
Old Feb 25, 2006 | 03:05 AM
minytrker's Avatar
Here is what I am going by. Thats wot from 4000-4800rpm
Old Feb 25, 2006 | 06:37 AM
ringram's Avatar
iat spark modifier can add or remove timing too.
you need to log rpm vs g/cyl to check the right cell. you can also log spark modifiers
Old Feb 25, 2006 | 09:39 AM
Yes, what he said.
You're not showing the rest of the table. Do you have 24* in all the cells of the table?
Old Feb 25, 2006 | 10:42 AM
minytrker's Avatar
Im am showing the part that is selected from my log. In the log the timing is 28-29 and you can the highlighted area is showing 24 and 26. Do I have to build a map for rpm vs g/cyl? If so why labels do I use? I logged g/cyl but its only under data.
Old Feb 25, 2006 | 11:30 AM
BLK02WS6's Avatar
If you send me your tune, I can take a look at it for you. E-mail it to me at BLK02WS6@aol.com
Old Feb 25, 2006 | 12:30 PM
minytrker's Avatar
Thanks I am sending it now.
