Knock Retard Problem? Need some expert advice.
TIA
Having KR at part-throttle is the best thing for the motor, but as long as your KR is functioning properly, your PCM will do its best to keep detonation to a minimum.
One problem that you may want to consider is that without some timing table modifications, your car may kick to the Low Octane Table. This will lower both your part-throttle and WOT timing. The car will run slower on the Low Octane Table, until you put 5 gallons of gas in it.
Good Luck,
Kevin
Thanks again,
Randy
<strong> If you raised the compression of your motor, you may have to retard timing slightly at part-throttle to get rid of the KR.
Good Luck,
Kevin </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am interested in this. I have heard that about the low gas going to the low octane tables. Is there anything I can read to see this?
I don't believe this is the case with my 2000 truck,as I have compared Autotap reads and paid attention to timing and KR, and not seen a difference between full of gas, and almost out. Very interesting though. Thanks in advance! Sam
The PCM resets this safety function when 5+ gallons of gas are put into the car.
Your gas level does not effect timing unless you have already been kicked to the Low Octane Table, and your car is just waiting for some better gas to get put in before it goes back to the normal High Octane table.
Good Luck,
Kevin
