does hptuners have....
Old Mar 6, 2006 | 08:46 AM
ninobrn99's Avatar
Question does hptuners have....
a histo that works like the RAF, where you log the right pids, then copy and paste? Is there no simple way to tune for timing? There isnt a standard way to do it is there? Just curious.
Old Mar 6, 2006 | 09:04 AM
horist's Avatar
I believe soundengineer designed a histogram that does the RAF, I'll check for it in a bit.
Regarding timing, the KR histo is what I generally use for timing tuning... (w/out being on a dyno its all guess work)
Old Mar 6, 2006 | 09:30 AM
foff667's Avatar
LS1TECH Sponsor
yeah the raf custom histo should be included witht eh latest version of 2.1...just click on open when in the histograms and idle desired airflow...most are still using ltit + stit though so its up to you if you'd like to change the pid used.
Old Mar 6, 2006 | 09:36 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Hmmmmmmmmm...maybe I'll check this one out. I just made my own with 2.0.xx.
Old Mar 6, 2006 | 09:55 AM
foff667's Avatar
LS1TECH Sponsor
i mean its been included for months now...i think since it was it beta...personally i just made my own as well, but just another thing to check out i guess
Old Mar 7, 2006 | 04:44 AM
ninobrn99's Avatar
so then what? i just subtract whatever knock im getting in the histo from my spark tables? generally, whats the best way to add timing and where do i start? bottom right or top left?
Old Mar 7, 2006 | 04:45 AM
ninobrn99's Avatar
thats another thing.. how do you create custom pids? i mean how do u know what to add and what to log in order to get a certain value for something else? i.e [pid.xxxx] + [pid.xxxx] where do u get those numbers from?
Old Mar 7, 2006 | 06:37 AM
foff667's Avatar
LS1TECH Sponsor
its actually all in the scanner help file
Old Mar 7, 2006 | 06:46 AM
ninobrn99's Avatar
found it thanks bill!
