Anyone figured out ground offsets with LC-1?
I am running HPtuners EIO and LC-1. My AFR from the LC-1 is through the roof all the time. If I start logging with the 12V source to LC-1 disconnected the RAW voltage read by Hptuners is 0.757V. When I plug in the 12V source it goes to a steady 2.08 V during LC-1 warmup (light blinking), then when the LC-1 is warmed up (light steady) the LC-1 reads 3.9-4.9 range during a 10 minute idle log.
How do I determine what ground offset I have so I can subtract that from the read in voltage and create a custom PID in hptuners to get an accurate reading? What can I use to calibrate the LC-1?
Thanks
Thanks
How do you have this wired up? Do you have the system and analog grounds together and the heater ground by it'self? What 12v source are you using? The fuse box? Cig lighter? Where physically are you grounding the sys/ ana and heater grnds?
Any ideas? Anything look fishy?
THanks
7 Second Club
Here's what I did....
Started car up and.....once it was warm with the wideband running....
Turned on the Lm1 logger and the HPT logger
Commanded A/F 13.5 60 seconds, 14.5 60 seconds, 15.5 60 seconds
Logged LM1 and HPT
Exported log and averaged 0 - 60; 61 - 120; 121 - 180 seconds
LM1 will average data @ 13.x 14.x and 15.x
Initally LM1 was .34-.38 lower than HPT at all 3 A/F levels
Corrected the voltage -.25
Did the same test and....
2nd round LM1 was .08-.10 lower than HPT actual LM1 -13.5 HPT 13.6 ; LM1 14.5 HPT 14.6
Corrected the voltage -.09
Did the same test and all 3 areas were within .01.
Logged LM1 and HPT
Originally Posted by oange ss
green/white to EIO ground
heater ground to chassis ground
cal wire to chassis ground
Anyone want to run out and see what their raw voltage is without the car running once the LC-1 is warmed up and the light is steady?
NOTE: I am reading these values through the EIO and hptuners. My serial hookup to the LC-1 is buried underneathy my PCM
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
The heater ground has to be seprate from the analog / system ground. The aux battery post is hot all the time. You don't want your sensor on all the time? If you pull the fuse connector that is on the drivers side dash/door you should find a suitable aux connector that will be set to turn on only with the ignition. If you get the mulitiple flashes after the cal sequence- is the HP tuners plugged into the vpw port?
As far as not having a display for the LC-1 I guess you mean when you don't have the laptop in the car? The LC-1 has two analog outputs that if you wanted to put in a cheap indicator I suppose you could. Doesn't Hptuners Data Log? What is the point of having two dataloggers in the vehicle? (HP + LM1?)
I'm confused.
I'm confused.
I'm confused.
I'm confused.
VPW port? Not sure what that is!
Originally Posted by 99whitews6
Tried moving my cal wire to chassis ground like your doing and all this did was make the light blink fast while after it was done warming up and then it went solid. Raw voltage once it was a steady light was a steady 4.917 V.
cal wire isnt suppose to be wired directly to ground, put a momentary switch between ground and the wire, use it to do free air cal...4.97v would be around 22 AFR which is what it's suppose to read in free air or air absent of exhaust....redo cal wire and you should be good to go
Originally Posted by Phil99vette
One thing I am not sure I like or not about the LC1 is there is nothing to compare it to. With the LM1 you have the display which will flatline @ calibration and while cruising when you know A/F should be 14.7 the Wideband will read exactly 14.7+-.5.
Phil
Phil
The reason why it is necessary to have the EIO connected to it is it will share the same ground with the PCM thru that connector. When I first set up my LC-1 I though ok I will set up one thing at time and got the flashing light thing and so I hooked up the scanner to the vpw connector and bingo it worked.
NOTE: Right now my cal wire goes through an LED and directly to ground is this my issue? I dont have any momentary switches( or any switches for that matter) at the present time.
Confused. I thought you were supposed to hook it up to ground. And IF you want you can put a switch for cal and a LED in parallel. So it would still always be connected to ground, right?
7 Second Club
I'm confused.
I'm confused.
