odd timing issues, not getting full advance
once the car goes past about 5800 rpm the timing goes from 28* down to about 26.5*, wtf? it should stay at 28*, any ideas?
I guess I could zero out the correction tables one by one until I find it.. hopefully.
ECT
IAT
EGR
TCS
Torque management
fuel mixture spark correction,
and don't forget about the multipliers that factor by RPM too.
So what happens if you bump the timing up to 30* in the table?
do you then see 28* on the scan?
ECT
IAT
EGR
TCS
Torque management
like i said, all mult table are zeroed out in the area this happens. and i havent touched the wot timing yet beucase we havent had the car out for a log recently.
BTW, you run into some wierd problems man.
Hell, you have my file. Do a compare and see.
i have a 1998 and the value is .020 but the range says 0.0 to 8.0
i know 1999+ cars have a range of values for the rpm..but 1998s only have 1 number to use throughout the rpm range.
what does yr burst numbers look like now?
