check engine light is flashing
Old Mar 29, 2006 | 10:34 PM
underatedT/A's Avatar
Default check engine light is flashing
all of a sudden my check engine light started flashing and remains on. the car runs like it is missing or getting to much fuel and running real rich. i tried resetting the computer and it works for maybe 5 mins then the car starts doing the same thing. oddly at wide open throttle the car seems to pull harder now WTF? any suggestions?
Old Mar 30, 2006 | 12:28 PM
camracingah's Avatar
We're taking the Z to the shop tomorrow. We detected a mis-fire and some odd little stuff. Same little things you reported. I'll give an update.
Old Mar 30, 2006 | 05:07 PM
thanks cam
Old Mar 30, 2006 | 05:13 PM
Predator's Avatar
Are your plug wires seated?
Old Mar 30, 2006 | 05:41 PM
yes the wires are seated for some reason i think it's one of the o2's going bad. i just need to get it scanned i will be stopping by autozone in the morning to get it scanned for free. thanks guys
Old Mar 30, 2006 | 05:53 PM
Dave D's Avatar
It is a misfire. O2 won't flash the light, and your car will go into loop mode if they are bad. the way I found my misfire was at night, I lifted the hood and there was an electrical storm of current going from the wires to the headers. I bought new wires and wrapped both the headers and the wires. I suggest looking at night or in total darkness. if you have headers you might have lightly melted a wire enough to arch.
Old Mar 30, 2006 | 05:57 PM
EDS01SS's Avatar
check your main coil wire connector.I just had the same problem and thats what it was
Old Apr 3, 2006 | 08:33 AM
Well. it turns out the plugs that we got for the Z were wrong. Replaced them with some NGK. Then we came across some bad fuel. Dirty. Anyhow got the injector cleaned. Now everything is okay, back to the norm except for that damn 02 oxygen sensor. Check that stuff.
