Car not following commanded AFR?
The wideband values being funky are probably just the sensor getting warmed up. The LM1 I use does something similar a lot of the time.
Wideband correctly tracks stoich and PE within a couple of %, when the car is fully warmed up.
But it shows lean during warmup. Even at 150 degrees ECT, it's still running leaner than stoich, even though the commanded afr is still rich. Finally around 176 it's almost there but still lean, and at 190 it's running just a tad richer than commanded.
When it's showing lean, it runs like it's lean too, hesitant to get moving. So it's not a "false" wideband reading.
60 lb mototrons, SD tune.
For reference, my afr error histogram shows my VE is right on at idle at 190 degrees.
The same histogram wants me to add 15% to VE at coolant temps under 170.
