Help. What could be wrong? Car is weird.
We got P0107,p0342,p0122,p0449,Po154, Ia was at -40 coolat temp was at -40 and all kinds of weird stuff.
After we turned off the car we started the car up and scaned again and some of the codes diasaperd,and the map sensor started to wrok . I really dont know how to explain what was going on because I dont know much about tuning,scanning our electronics our DTC trouble codes.
I talked with the guy who scaned my car and he will post up here, and will better explain what was going on.
I am running a TSP mail order tune With PRC heads and a 233/239/598-603 113lsa cam,Vig 3800,LTs, And ls6 intake with bbk 80mm tb.
I would really appreciate any help our information .
Thank you very much for reading.
The MAP sensor is acting very weird in this car. When I first got there we started the car and the MAP was flatlined at 0 kPa. I cleared all the DTCs and when we restarted the car the MAP sensor magically started working. After a few moments though, it flatlined again this time at 10 kPa. We tried different MAP sensors, but got the same result each time.
Some other things I saw in hpt were dead O2s (omV) and maxed out fuel trims (100%). He has MAF voltage, so I know the ENG SENS fuse is ok.
Also the car is a 98 with ac, egr and air deleted.
Chris, did you notice anything after taking the intake off? When I have some free time, I'll take a closer look at it. Hopefully your hpt cable will be in the mail soon!
Thanks Brian for posting up.
I took the intake off right after you left, Everthing looked okay, but there is a posibility that the knock sensor wire was pinched under the intake mani. Still have the intake off right now, not sure if i should put it back on yet.
What is a dmm?
right on man let me know.
