using hp tuner to switch vin/transmission
Old May 11, 2006 | 12:54 PM
black98ws6ta's Avatar
Default using hp tuner to switch vin/transmission
I have a 98 automatic that Im going to be switching to a 6 spd, I also have hptuners for the car, what do I need to do to flash the computer to work with a 6 spd? Thanks
Old May 11, 2006 | 01:01 PM
Black02SS's Avatar
All you really need to do is flash a 98 M6 Calibration into the pcm and you should be good to go.
Old May 11, 2006 | 01:02 PM
Specifically how do I do that? I seen where could change vins, but nothing else. Thanks
Old May 11, 2006 | 01:06 PM
foff667's Avatar
LS1TECH Sponsor
I thought it was a must that you HAD to throw in the OS & such that came out of your computer with the 98's...could be wrong since I havent had to do an OS changes as of yet.
Black02SS's Avatar
You will need to find a M6 98 file and flash it.
Old May 11, 2006 | 01:16 PM
Lostpatrolman's Avatar
I have a stock 98 with m6 file you can have.
Old May 11, 2006 | 02:34 PM
SMOKINV8's Avatar
I'm not sure if you can do that with the new MPVI interface, I know you can't edit and save files from another VIN.
You'll want to do a complete rewrite with the M6 bin, and there's no problems with 98's. I did this a while back (pre-MPVI).
Old May 11, 2006 | 03:56 PM
How exactly is this done, I am not a hp tuner expert.
Old May 13, 2006 | 11:39 PM
black98, what version of the cable do you have? Does it have a USB end, or serial?
Old May 15, 2006 | 06:07 PM
It is usb and the newest version I believe I just got it like 2 weeks ago.
